Just updated to 22.04 and read that it now supports wayland for nvidia card with nvidia 510 driver. I've got nvidia 2080 super and I can not see the cog in the right bottom corner on the login screen. Changing WaylandEnabled to true in config file doesn't work as well. Am I missing something?
Asked
Active
Viewed 4,983 times
sudo open /usr/lib/udev/rules.d/61-gdm.rules
LABEL="gdm_prefer_xorg"
#RUN+="/usr/lib/gdm-runtime-config set daemon PreferredDisplayServer xorg"
GOTO="gdm_end"
LABEL="gdm_disable_wayland"
#RUN+="/usr/lib/gdm-runtime-config set daemon WaylandEnable false"
GOTO="gdm_end"
Add # to the two lines like what is shown above (scroll all the way down, both are at the bottom. Save and reboot; original solution can be found here by Pablo Bianchi
tested and works on 22.04 too. If encounter any problems simply un # the two lines.
ManOnTheMoon
- 1,512
- 8
- 21
