lubuntu@lubuntu:~$ sudo apt install microsoft-edge-dev
Reading package lists... Done
Building dependency tree
 microsoft-edge-dev : Depends: libatomic1 (>= 4.8) but it is not going to be installed
lubuntu@lubuntu:~$ sudo apt install libatomic1
 libatomic1 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is to be installed
lubuntu@lubuntu:~$ neofetch
        #####           lubuntu@lubuntu
       ##O#O##          OS: Boot-Repair-Disk 64bit 20200604 x86_64
       #######          Host: HP Slimline Desktop PC 270-p0XX
     ###########        Kernel: 5.3.0-28-generic
    #############       Uptime: 10 days, 2 hours, 13 mins
   ###############      Packages: 1093
   ################     Shell: bash 4.4.20
  #################     Resolution: 1440x900
#####################   DE: LXDE
#####################   WM: Openbox
  #################     Theme: Adwaita [GTK3]
                        Icons: Adwaita [GTK3]
                        Terminal: lxterminal
                        Terminal Font: Monospace 10
                        CPU: Intel i3-7100 (4) @ 3.900GHz
                        GPU: Intel HD Graphics 630
                        Memory: 2167MiB / 3829MiB
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Boot-Repair-Disk 64bit 20200604
Release:    18.04.4
Codename:   bionic
karel
  • 122,292
  • 133
  • 301
  • 332
