I already was able to change the icon of the Main Menu in the panel of Mate using these suggestions
Change icon on MATE main menu
Yesterday, suddenly menu was gone, I fixed it and eanted to assign "my" icon again, doing the same procedure. This time it did not work...
I started dconf-editor
mate > panel > menubar add my requested file name without and with or without path: Mein Menu icon does not change (that is the one with the little arrow on top). I use the Numix Circle Icon set, and want to have an icon from the very same set. Do not understand, because i did it once, and it worked
To the suggestion below saying: "if you want to have a custom icon, copy the .svg image to /usr/share/icons/apps/image.svg replace image with the image title of course..."
I do not have such a path... /usr/share/icons/apps... Thanks for any help
B.
Buelent
  • 71
I intended to change the provides icon for the Main Menu applet in the Mate-Panel. This is how I succeeded: I opened dconf-editor then: /org/mate/panel/objects
  • Objects - staying for each applet in the panel - are numbered, some of them can be identified immediately by the line in "custom-id", but most of them are not. I have about 15 objects there, each standing for an applet on may panel in Mate. I identified the Main Menu applet (in my case #12) by switching the "has-arrow' line on/off
  • then I unlocked "custom icon"
  • and in a next step I specified the location of the icon I wanted want to use in "custom icon"
Hope this clearer now. By this procedure one can change anyIcon in the startin applets in the panel B.
Buelent
  • 71
