I want to install onboard on my Ubuntu 20.04. It is giving me this error:
Reading package lists... Done
Building dependency tree
onboard : Depends: python3 (< 3.8) but 3.8.2-0ubuntu2 is to be installed
Recommends: gir1.2-ayatanaappindicator3-0.1 but it is not going to be installed
Recommends: gir1.2-atspi-2.0 but it is not going to be installed
Recommends: onboard-data (>= 1.4.1-4) but it is not going to be installed
I have 3 Python versions installed (3.8.10 <- preinstalled, 3.10.4 and 3.11.0a7). apt is only detecting Python 3.8. Fix possible?
Edit: I am sure my system does not contain broken packages (when I install other stuff the error does not appear). So I think it is related to the installation.
