I have 2 SSDs: 500GB SSD splitted to 250GB of Windows 10 and 250GB of Ubuntu 20.04
The other 250GB SSD is only Windows 10.
I installed Ubuntu 20.04 and the GRUB was somehow installed on the wrong drive (The one that does not have Ubuntu on it - it has Windows 10 on it)
I currently see 2 GRUBs: One on the wrong drive which is a working GRUB menu, and other on the drive with Ubuntu, but when I launch it, it shows me "GRUB minimal bash"
I followed this post to remove GRUB via Windows: Uninstall GRUB and use Windows bootloader
Then I tried to reinstall GRUB on the correct drive using this article:
https://www.geeksforgeeks.org/how-to-fix-minimal-bash-like-line-editing-is-supported-grub-error-in-linux/
But it doesn't work, after a restart, I once again get 2 GRUBs with same configuraton: 1 working GRUB on the wrong drive, and 1 "minimal bash" grub on the drive with Ubuntu.
What I'm trying to achieve is to have the working GRUB on the drive with Ubuntu installed on it, and remove the GRUB from the wrong drive without Ubuntu
Foobarer
  • 517
Welcome to AskUbuntu.
First of all, if you didn't make a specific other /boot partition on your 'Windows'-drive during install, don't delete any partition. In that case Grub is installed in the (only) EFI partition of that disk.( I have 2, so grub didn't mess with my windows-bootloader.)
There are several ways to uninstall Grub.
1 From Windows use a program called easybcd. The program can be found here https://neosmart.net/EasyBCD/
2 Using the command line in Windows as explained here. https://www.binaryera.com/2020/08/RemoveGrubFromWindow10.html.
3 Using a 'live'Ubuntu environment and the terminal.See https://help.ubuntu.com/community/Grub2/Uninstalling
This page gives you also several ways to uninstall grub. https://frameboxxindore.com/linux/how-do-i-remove-grub-after-uninstall-linux.html.
If you want to be absolutly sure which grub you uninstall, disconnect your Ubuntu-disk temporary. Connect it again after you uninstalled grub from your Windows-disk.
Joepie Es
  • 1,570
