Recently I tried to install Wine, but I tried to install Jammy version by accident, and now, when I try this command
sudo apt install --install-recommends winehq-staging
I get this output
Building dependency tree
winehq-staging : Depends: wine-staging (= 7.6~jammy-1)
How can I solve it? I don't get any errors with sudo apt update or sudo apt upgrade
sudo apt update
Ign:1 http://packages.linuxmint.com una InRelease
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:4 http://packages.linuxmint.com una Release
Hit:5 https://packages.microsoft.com/ubuntu/21.04/prod hirsute InRelease
Hit:6 http://archive.canonical.com/ubuntu focal InRelease
Hit:7 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:8 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:10 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu focal InRelease
Hit:11 http://packages.microsoft.com/repos/code stable InRelease
Hit:12 https://dl.winehq.org/wine-builds/ubuntu focal InRelease
Hit:13 https://dl.winehq.org/wine-builds/ubuntu jammy InRelease
Reading package lists... Done
All packages are up to date.
sudo apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
If I try to unhold all held packages I get this output
sudo apt-mark unhold $(apt-mark showhold)
E: No packages found
I've tried with these aptitude commands
sudo aptitude install winehq-staging
sudo aptitude -f install winehq-staging
but they don't seem to solve anything, the actions that aptitude do are just keep the packages at their current version.
I downloaded winehq-staging_7.6~focal-1_amd64.deb and I got this output
sudo dpkg -i --force-all winehq-staging_7.6~focal-1_amd64.deb
Selecting previously unselected package winehq-staging.
(Reading database ... 378899 files and directories currently installed.)
Preparing to unpack winehq-staging_7.6~focal-1_amd64.deb ...
Unpacking winehq-staging (7.6~focal-1) ...
dpkg: winehq-staging: dependency problems, but configuring anyway as you requested:
winehq-staging depends on wine-staging (= 7.6~focal-1); however:
Package wine-staging is not installed.
Setting up winehq-staging (7.6~focal-1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for desktop-file-utils (0.24+linuxmint1) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for man-db (2.9.1-1) ...
but wine seems to still being unavailable. I tried to remove the broken package using Synaptic Package Manager, the first try it was unable to remove it, then I did it again and the broken package seems to be already removed. But I keep getting this output
Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 5075 (synaptic)
and sudo apt update keeps showing
Hit:10 https://dl.winehq.org/wine-builds/ubuntu jammy InRelease
I just got the git repository and build it with make and seems that that solved the problem. But I still having the https://dl.winehq.org/wine-builds/ubuntu jammy InRelease line.
