I am getting an error for upgrading Ubuntu packages, it suggested running apt --fix-broken install but doing that didn't do it. I searched and the only answer I found was removing the packages which I am reluctant to do, cause I might mess it up.
I installed python3.10 some months ago, and my projects depend on it.
sudo apt-get upgrade
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libpython3.10 : Depends: libpython3.10-stdlib (= 3.10.4-1+focal2) but 3.10.4-1+focal1 is installed
libpython3.10-dev : Depends: libpython3.10-stdlib (= 3.10.4-1+focal2) but 3.10.4-1+focal1 is installed
python3.10-minimal : Depends: libpython3.10-minimal (= 3.10.4-1+focal2) but 3.10.4-1+focal1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
- Running
sudo apt --fix-broken install
dpkg: error processing archive /var/cache/apt/archives/libpython3.10-stdlib_3.10.4-1+focal2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/python3.10/_sysconfigdata__linux_x86_64-linux-gnu.py', which is also in package libpython3.10-minima
l:amd64 3.10.4-1+focal1
Preparing to unpack .../libpython3.10-minimal_3.10.4-1+focal2_amd64.deb ...
Unpacking libpython3.10-minimal:amd64 (3.10.4-1+focal2) over (3.10.4-1+focal1) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.10-minimal_3.10.4-1+focal2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/python3.10/typing.py', which is also in package libpython3.10-stdlib:amd64 3.10.4-1+focal1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
