apt upgrade:
$ sudo apt-get full-upgrade -y
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libpython3.10 : Depends: libpython3.10-stdlib (= 3.10.4-1+focal2) but 3.10.4-1+focal1 is installed
libpython3.10-dev : Depends: libpython3.10-stdlib (= 3.10.4-1+focal2) but 3.10.4-1+focal1 is installed
python3.10-minimal : Depends: libpython3.10-minimal (= 3.10.4-1+focal2) but 3.10.4-1+focal1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
apt --fix-broken install:
$ sudo apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
libpython3.10-minimal libpython3.10-stdlib
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
9 not fully installed or removed.
Need to get 0 B/2,566 kB of archives.
After this operation, 68.6 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 279178 files and directories currently installed.)
Preparing to unpack .../libpython3.10-stdlib_3.10.4-1+focal2_amd64.deb ...
Unpacking libpython3.10-stdlib:amd64 (3.10.4-1+focal2) over (3.10.4-1+focal1) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.10-stdlib_3.10.4-1+focal2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/python3.10/_sysconfigdata__linux_x86_64-linux-gnu.py', which is also in package libpython3.10-minimal:amd64 3.10.4-1+fo
cal1
Preparing to unpack .../libpython3.10-minimal_3.10.4-1+focal2_amd64.deb ...
Unpacking libpython3.10-minimal:amd64 (3.10.4-1+focal2) over (3.10.4-1+focal1) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.10-minimal_3.10.4-1+focal2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/python3.10/typing.py', which is also in package libpython3.10-stdlib:amd64 3.10.4-1+focal1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Tried to remove installed python3.10 packages but it results in error Unmet dependencies
What does this error message means and is there's a way to fix it?
