I tried to dual boot windows to my 20.04 ubuntu machine. After successfully installing windows I found I can no longer access ubuntu.
The state right now:
  • I enter the bios and choose the ubuntu boot.
  • After choosing ubuntu the grub2 command line is prompted.
  • If I run grub> exit I exit the grub and the windows os is loaded.
  • after roaming the internet I found that there is a way to boot through the grub2.
  • if I run the suggested command :
grunb> set root=(hd1,msdos5)
grunb> linux /boot/vmlinuz-5.13.0-39-generic root=/dev/nvme1n1p5 ro
grunb> initrd /boot/inintrd.img-5.13.0-39-generic
grunb> boot
  • Next, it seems like ubuntu start to load but got stuck at (initramfs) and there are some notable error lines before:
Begin: running /script/int-bottom ... mount: mounting /dev on /root/dev
Mounting: mounting /dev on /root/dev failed: no such file or directory
done.
run-init: can't execute '/sbin/init': no such file or directory
target filesystem dosen't have requested /sbin/init
run-init: can't execute '/etc/init': no such file or directory
run-init: can't execute '/bin/init': no such file or directory
run-init: can't execute '/bin/sh': no such file or directory
run-init: can't execute '': no such file or directory
No init found. Try passing init= bootarg
(initramfs)
More data:
  • Even before I added windows, ubuntu will first load the grub command line, and then I would have to enter grub>exit to enter ubuntu.
  • I use a new m.2 512GB disk for the windows installation.
  • I can view all of my files and directory of the Ubuntu partition using the Grub ls command.
  • Some grub> ls command ouput:
Grub> ls
(proc) (hd0) (hd0,gpt5) (hd0,gpt4) (hd0,gpt3) (hd0,gpt2) (hd0,gpt1) (hd1) (hd1,msdos5) (hd1,msdos1)
Grub> ls (hd1,msdos5)/ lost+found/ boot/ swampfile etc/ media/ var/ bin dev/ home/ lib lib32 lib64 libx32 mnt/ opt/ proc/ root/ run/ sbin snap/ srv/ sys/ tmp/ usr/ cdrom/ -(My ubuntu partition)
Grub> ls (hd0,gpt2)/ efi/
Grub> ls (hd0,gpt4)/ /Program File /Program File (x86) ...
  • (My Windows partition...)
Grub> ls (hd1,msdos1)/ efi/ System Volume Information/ $recycle.bin/ Recovery
  • (ubuntu efi boot?)
Grub ls (hd1,msdos1)/efi/ ubuntu/ boot/
  • Some grub> set command ouput:
Grub> set
cmdpath=(hd1,msdos1)/EFI/UBUNTU
grub_cpu=x86_64
grub_platform=efi
lang=
locale_dir=
prefix=(hd1,msdos1)/boot/grub
root=hd1,msdos1
some failed methods:
  • I tried to boot Linux on live cd and update the grub
  • I tried to use boot-repair
  • I tried to add those lines to the grub:
Grub> set prefix=(hd1,msdos5)/boor/grub
Grub> insmod normal
Grub> normal
  • I tried to change the root folder of the linux command to root=/dev/sda1 ro. As far as I understand I should use the nvme1n1p5 as my disks are m.2 type.
  • I have seen somewhere that you can't dual boot legacy bios with UEFI and that I should change this setting in the bios. but all the relevant options were on "legacy bios only"
So, this is my last painful experience with dual booting. I hope I have been clear enough. If you need any other information please tell me. And of course, thank you very much for the will to help me :)
update:
After reading the boot-repair report: https://paste.ubuntu.com/p/VG5skMbhVk/ I realize that in the second line of the Grub I should have written nvme0n1p5 instead of nvme1n1p5, Currently, I'm successfully booted into my ubuntu.
Right now I am not sure how to update my grub. My end goal would be that when powering the computer I'll be prompt with a grub menu with ubuntu and windows.
