I have had issues with my Ubuntu server after it crashed during a release-upgrade. I was upgrading from Ubuntu 18.04 to 20.04 using the do-release-upgrade command. I did a CTRL+C by accident during the process and I had to hard restart the system. The system currently displays 'Ubuntu 20.04' so I guess the upgrade was partially successful.
I managed to recover access to the system via SSH and I'm now trying to fix the issues. Running apt-get upgrades I've noticed that dpkg was throwing errors about the grub-common package:
root@caesarovich:~# apt-get install -f
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libnginx-mod-http-geoip libunistring2:i386
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 289 not upgraded.
6 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up grub-common (2.04-1ubuntu26.15) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Failed to restart grub-common.service: Unit grub-common.service is not loaded properly: Exec format error.
See system logs and 'systemctl status grub-common.service' for details.
invoke-rc.d: initscript grub-common, action "restart" failed.
● grub-common.service - Record successful boot for GRUB
Loaded: error (Reason: Exec format error)
Active: inactive (dead)
Apr 07 14:35:20 caesarovich.xyz systemd[1]: /lib/systemd/system/grub-common.service:10: Executable path is not absolute: grub-editenv /boot/grub/grubenv unset recordfail
Apr 07 14:40:57 caesarovich.xyz systemd[1]: /lib/systemd/system/grub-common.service:10: Executable path is not absolute: grub-editenv /boot/grub/grubenv unset recordfail
Apr 07 14:40:58 caesarovich.xyz systemd[1]: /lib/systemd/system/grub-common.service:10: Executable path is not absolute: grub-editenv /boot/grub/grubenv unset recordfail
Apr 07 14:41:18 caesarovich.xyz systemd[1]: /lib/systemd/system/grub-common.service:10: Executable path is not absolute: grub-editenv /boot/grub/grubenv unset recordfail
Apr 07 14:50:28 caesarovich.xyz systemd[1]: /lib/systemd/system/grub-common.service:10: Executable path is not absolute: grub-editenv /boot/grub/grubenv unset recordfail
Apr 07 14:50:29 caesarovich.xyz systemd[1]: /lib/systemd/system/grub-common.service:10: Executable path is not absolute: grub-editenv /boot/grub/grubenv unset recordfail
dpkg: error processing package grub-common (--configure):
installed grub-common package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of grub-efi:
grub-efi depends on grub-common (= 2.04-1ubuntu26.15); however:
Package grub-common is not configured yet.
dpkg: error processing package grub-efi (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of grub-efi-amd64-bin:
grub-efi-amd64-bin depends on grub-common (>= 2.02~beta2-9); however:
dpkg: error processing package grub-efi-amd64-bin (--configure):
dpkg: dependency problems prevent configuration of grub-efi-amd64:
grub-efi-amd64 depends on grub-efi-amd64-bin (= 2.04-1ubuntu44.2); however:
Package grub-efi-amd64-bin is not configured yet.
dpkg: error processing package grub-efi-amd64 (--configure):
dpkg: dependency problems prevent configuration of grub2-common:
grub2-common depends on grub-common (= 2.04-1ubuntu26.15); however:
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: error processing package grub2-common (--configure):
dpkg: dependency problems prevent configuration of grub-efi-amd64-signed:
grub-efi-amd64-signed depends on grub-efi-amd64-bin (= 2.04-1ubuntu44.2); however:
grub-efi-amd64-signed depends on grub-efi-amd64 | grub-pc; however:
Package grub-efi-amd64 is not configured yet.
Package grub-pc is not installed.
grub-efi-amd64-signed depends on grub2-common (>= 2.02~beta2-36ubuntu3.31); however:
Package grub2-common is not configured yet.
dpkg: error processing package grub-efi-amd64-signed (--configure):
grub-common
grub-efi
grub-efi-amd64-bin
grub-efi-amd64
grub2-common
The line that caught my eyes is this one:
But I don't find anything about this error on the web. I wonder if anyone knows what it is about. Any hint might be welcome !
Edit: Here's additional information requested
~# cat /lib/systemd/system/grub-common.service
[Unit]
Description=Record successful boot for GRUB
After=sleep.target
ConditionPathExists=/boot/grub/grub.cfg
[Service]
Type=oneshot
Restart=no
ExecStartPre=/bin/sh -c '[ -s /boot/grub/grubenv ] || rm -f /boot/grub/grubenv; mkdir -p /boot/grub'
ExecStart=grub-editenv /boot/grub/grubenv unset recordfail
ExecStartPost=/bin/sh -c 'if grub-editenv /boot/grub/grubenv list | grep -q initrdless_boot_fallback_triggered=1; then echo "grub: GRUB_FORCE_PARTUUID set, initrdless boot paniced, fallback triggered."; fi'
StandardOutput=kmsg
[Install]
WantedBy=multi-user.target sleep.target
command: file /usr/bin/grub-editenv
/usr/bin/grub-editenv: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=e9970f097fb3d25735e9607c0cb1da91505f8f92, for GNU/Linux 3.2.0, stripped
[SOLVED]
I did not have many time lately to get over the issue but today i came back with a fresh mind, and managed to solve the issue.
The problem was that in grub-common.service the ExecStart was not absolute. FIX: Edit the .service file and make the path absolute ExecStart=/usr/bin/grub-editenv instead of ExecStart=grub-editenv.
