Recently I had a problem with the fan working all the time.
Someone suggested to use powertop --auto-tune or to write auto into /sys/bus/pci/devices/0000\:01\:00.0/power/control
My question is:
What is /sys/bus/pci/devices/0000\:01\:00.0 ? - I guess it points to some device (probably my NVIDIA graphic controller). How do I know which device is which? What is meant by 0000 and :01 and :00.0? - Where can I find an explanation for how the devices are written?
Nmath
  • 12,664
aviv
  • 158
/sys/bus/pci/devices/0000:01:00.0/power/control
  • sys is a virtual filesytem that allows you to get information about the system and its components in a structured way.
  • /sys/bus/ This directory contains one subdirectory for each of the bus types in the kernel. Inside each of these directories are two subdirectories:
           devices
                  This subdirectory contains symbolic links to
                  entries in /sys/devices that correspond to the
                  devices discovered on this bus.
       drivers
              This subdirectory contains one subdirectory for
              each device driver that is loaded on this bus.
The 0000:01:00.0:
  • "0000" is the PCI domain
  • "01" points to the PCI bus number in that domain
  • "00" is the device number
  • "0" is the function in the device
Often you see it described like this: /sys/bus/pci/devices/<Domain>:<Bus>:<Device>.<Function>/power/control
  • power/controle is used to manipulate runtime power management.
nvidia has a large manual on this. Chapter 22 is about this function.
Rinzwind
  • 309,379
