I am facing troubles with getting kontact to run:
Installed it via:
sudo flatpak install flathub org.kde.kontact
Output of:
/usr/bin/flatpak run --branch=stable --arch=x86_64
--command=kontact org.kde.kontact Trying to create ksycoca... org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-cmd.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-cmd.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-cmd.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! Cannot initialize model with data QJsonObject(). missing: QJsonValue(string, "urls") org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-cmd.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Akonadi Client Session: connection config file 'akonadi/akonadiconnectionrc' can not be found! org.kde.pim.akonadicore: "QLocalSocket::connectToServer: Ungültiger Name" "/home/benji/.var/app/org.kde.kontact/data/akonadiakonadiserver-ntf.socket" org.kde.pim.akonadicore: Failed to connect to server! org.kde.pim.akonadicore: Socket error occurred: "QLocalSocket::connectToServer: Ungültiger Name" org.kde.pim.akonadicore: Socket error occurred: "Failed to connect to server!" org.kde.pim.akonadicore: Socket error occurred: "QLocalSocket::connectToServer: Ungültiger Name" org.kde.pim.akonadicore: Socket error occurred: "Failed to connect to server!" org.kde.pim.akonadicore: Socket error occurred: "QLocalSocket::connectToServer: Ungültiger Name" org.kde.pim.akonadicore: Socket error occurred: "Failed to connect to server!" org.kde.pim.akonadicore: Socket error occurred: "QLocalSocket::connectToServer: Ungültiger Name" org.kde.pim.akonadicore: Socket error occurred: "Failed to connect to server!"
Kontact is starting but does not connect to my dav calenderst/contacts (via nextcloud instance) So it looks as if it were a first-run (interstingly inside the settings, my calenders/contacts are showing up and telling me that everything is ready and in sync)
Any suggestions how I can solve this issue?
Kontact Version 5.19.3 (21.12.3) Operating System: Kubuntu 20.04 KDE Plasma Version: 5.18.8 KDE Frameworks Version: 5.68.0 Qt Version: 5.12.8 Kernel Version: 5.4.0-99-generic OS Type: 64-bit Processors: 8 × Intel® Core™ i7-8565U CPU @ 1.80GHz Memory: 15,4 GiB
