How to disable zram at boot?
What I found was mostly to
swapoff -a
rmmod zram
but after reboot it came back
I found such question being asked at different places, e.g.,
But none seems to be able to get answered properly.
xpt
  • 1,197
On Arch Linux-based systems, it is possible that zram is configured via zram-generator package. The generator is invoked by systemd early at boot. You can check unit status of your configuration service via systemd-zram-setup@zramN.service. N is the zram device id. To disable generator, set systemd.zram[=0|1] kernel parameter.
sudo nano /etc/default/grub
Then add systemd.zram=0 argument to GRUB_CMDLINE_LINUX_DEFAULT as follows.
GRUB_CMDLINE_LINUX_DEFAULT="systemd.zram=0"
Then generate grub config file
sudo grub-mkconfig -o /boot/grub/grub.cfg
