I first tried to download in terminal
$ java
Command 'java' not found, but can be installed with:
sudo apt install openjdk-11-jre-headless # version 11.0.13+8-0ubuntu1~21.10, or
sudo apt install default-jre # version 2:1.11-72
sudo apt install openjdk-17-jre-headless # version 17.0.1+12-1~21.10
sudo apt install openjdk-8-jre-headless # version 8u312-b07-0ubuntu1~21.10
sudo apt install openjdk-15-jre-headless # version 15.0.3+3-1
sudo apt install openjdk-16-jre-headless # version 16.0.1+9-1`
Then I typed
it said
E: Failed to fetch http://mirror.ni.net.tr/ubuntu/pool/main/j/java-common/java-common_0.72build1_all.deb  404  Not Found [IP: 95.173.191.11 80]
E: Failed to fetch http://mirror.ni.net.tr/ubuntu/pool/main/o/openjdk-lts/openjdk-11-jre-headless_11.0.13%2b8-0ubuntu1%7e21.10_amd64.deb  404  Not Found [IP: 95.173.191.11 80]
E: Failed to fetch http://mirror.ni.net.tr/ubuntu/pool/main/j/java-common/default-jre-headless_1.11-72build1_amd64.deb  404  Not Found [IP: 95.173.191.11 80]
E: Failed to fetch http://mirror.ni.net.tr/ubuntu/pool/main/o/openjdk-lts/openjdk-11-jre_11.0.13%2b8-0ubuntu1%7e21.10_amd64.deb  404  Not Found [IP: 95.173.191.11 80]
E: Failed to fetch http://mirror.ni.net.tr/ubuntu/pool/main/j/java-common/default-jre_1.11-72build1_amd64.deb  404  Not Found [IP: 95.173.191.11 80]
E: Failed to fetch http://mirror.ni.net.tr/ubuntu/pool/main/j/java-atk-wrapper/libatk-wrapper-java_0.38.0-2ubuntu3_all.deb  404  Not Found [IP: 95.173.191.11 80]
E: Failed to fetch http://mirror.ni.net.tr/ubuntu/pool/main/j/java-atk-wrapper/libatk-wrapper-java-jni_0.38.0-2ubuntu3_amd64.deb  404  Not Found [IP: 95.173.191.11 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Then I tried
but it said
E: Unable to locate package openjdk-11-jre-headles
I just switched from Windows and I am struggling to install java on my newly installed Ubuntu. If you can help me i will be very happy thank you.
I've found that I cant download anything at the moment as it always says unable to fetch. I think I messed up something before.
Zanna
  • 72,312
Hello somehow i solved the problem bu changing my download server i remembered that i changed my default server to http://mirror.ni.net.tr which was not working than i scanned for the best server for me it was ubuntu.torhost.com which worked fine that i could download what i want in terminal. Note: thanks for who answered my question to help me :)
