I followed this article to install mariadb on Ubuntu 20.04.4 LTS. However, I was shown these messages
Reading package lists... Done
Building dependency tree
mariadb-server : Depends: mariadb-server-10.3 (>= 1:10.3.34-0ubuntu0.20.04.1) but it is not going to be installed
Thus, I couldn't start the server or check its status. I've tried to remove repos of mariadb as this post suggested, but no repos available. What should I do?
UPDATED: When I use sudo apt update, the following appear
Hit:1 http://vn.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://vn.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://vn.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu focal-security InRelease
10 packages can be upgraded. Run 'apt list --upgradable' to see them.
