When restarting the apache server with this command sudo service apache2 restart I get an error
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
journalctl | tail
Apr 02 11:43:34 raspberrypi sudo[11952]: pam_unix(sudo:session): session closed for user pi
Apr 02 11:43:46 raspberrypi sudo[11965]: root : PWD=/usr/share/piwiz ; USER=pi ; ENV=XDG_RUNTIME_DIR=/run/user/1000 ; COMMAND=/usr/bin/
Apr 02 11:43:46 raspberrypi sudo[11965]: pam_unix(sudo:session): session opened for user pi(uid=1000) by (uid=0)
Apr 02 11:43:49 raspberrypi sudo[11965]: pam_unix(sudo:session): session closed for user pi
Apr 02 11:44:01 raspberrypi sudo[11979]: root : PWD=/usr/share/piwiz ; USER=pi ; ENV=XDG_RUNTIME_DIR=/run/user/1000 ; COMMAND=/usr/bin/
Apr 02 11:44:01 raspberrypi sudo[11979]: pam_unix(sudo:session): session opened for user pi(uid=1000) by (uid=0)
Apr 02 11:44:04 raspberrypi sudo[11979]: pam_unix(sudo:session): session closed for user pi
Apr 02 11:44:16 raspberrypi sudo[11992]: root : PWD=/usr/share/piwiz ; USER=pi ; ENV=XDG_RUNTIME_DIR=/run/user/1000 ; COMMAND=/usr/bin/
Apr 02 11:44:16 raspberrypi sudo[11992]: pam_unix(sudo:session): session opened for user pi(uid=1000) by (uid=0)
Apr 02 11:44:19 raspberrypi sudo[11992]: pam_unix(sudo:session): session closed for user pi
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2022-04-02 11:42:38 CEST; 5min ago
Docs: https://httpd.apache.org/docs/2.4/
Process: 11891 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
CPU: 87ms
Apr 02 11:42:38 raspberrypi apachectl[11894]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, usi>
Apr 02 11:42:38 raspberrypi apachectl[11894]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
Apr 02 11:42:38 raspberrypi apachectl[11894]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
Apr 02 11:42:38 raspberrypi apachectl[11894]: no listening sockets available, shutting down
Apr 02 11:42:38 raspberrypi apachectl[11894]: AH00015: Unable to open logs
Apr 02 11:42:38 raspberrypi apachectl[11891]: Action 'start' failed.
Apr 02 11:42:38 raspberrypi apachectl[11891]: The Apache error log may have more information.
Apr 02 11:42:38 raspberrypi systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Apr 02 11:42:38 raspberrypi systemd[1]: apache2.service: Failed with result 'exit-code'.
Apr 02 11:42:38 raspberrypi systemd[1]: Failed to start The Apache HTTP Server.
