I am not all that new to Ubuntu (have been using it for 20 years now), but as all good friends, sometimes it still manages to surprise me.
After fresh install (Ubuntu 21.10 in an Asus ROG laptop) I cannot seem to get the wifi to work. I do not see a wifi icon and in settings-> wifi I get the wifi adapter not found error.
I am not an expert in Ubuntu (just a long term user) and I realize I know very little about how the wifi works.
As far as I can tell, the system is unable to find the wifi controller (I believe there isn't one).
I happen to know that the wifi controller does exist and works because this computer came with a preinstalled windows (not there anymore) with which I could use the wifi without problems. At this moment I am connected via wired connection which also works fine.
Any help would be very welcome.
I run the wifi diagnostic script that I found in the forum with the following results.
########## wireless info START ##########
Report from: 30 Mar 2022 14:35 JST +0900
Booted last: 30 Mar 2022 00:00 JST +0900
Script from: 25 Jan 2020 03:34 UTC +0000
release
Distributor ID: Ubuntu Description: Ubuntu 21.10 Release: 21.10 Codename: impish
kernel
Linux 5.13.0-39-generic #44-Ubuntu SMP Thu Mar 24 15:35:05 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
desktop
Ubuntu
lspci
0000:00:14.3 Network controller [0280]: Intel Corporation Device [8086:51f0] (rev 01) DeviceName: Onboard - Ethernet Subsystem: Intel Corporation Device [8086:0094]
0000:2c:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05) Subsystem: ASUSTeK Computer Inc. RTL8125 2.5GbE Controller [1043:205f] Kernel driver in use: r8125
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 002: ID 0b05:19b6 ASUSTek Computer, Inc. N-KEY Device Bus 003 Device 003: ID 8087:0033 Intel Corp. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCMCIA card info
rfkill
0: hci0: Bluetooth Soft blocked: no Hard blocked: no
secure boot
SecureBoot disabled
lsmod
mxm_wmi 16384 1 nouveau iwlwifi 380928 0 asus_nb_wmi 28672 0 wmi_bmof 16384 0 cfg80211 897024 1 iwlwifi asus_wmi 40960 3 asus_nb_wmi,hid_asus,mfd_aaeon sparse_keymap 16384 1 asus_wmi wmi 32768 5 asus_wmi,wmi_bmof,mfd_aaeon,mxm_wmi,nouveau video 53248 3 asus_wmi,i915,nouveau
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback <MAC address> brd <MAC address> inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: enp44s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether <MAC 'enp44s0' [IF1]> brd <MAC address> inet 133.24.25.175/23 brd 133.24.25.255 scope global noprefixroute enp44s0 valid_lft forever preferred_lft forever inet6 fe80::27d7:c858:c237:83df/64 scope link noprefixroute valid_lft forever preferred_lft forever
iwconfig
lo no wireless extensions.
enp44s0 no wireless extensions.
route
default via 133.24.24.254 dev enp44s0 proto static metric 100 133.24.24.0/23 dev enp44s0 proto kernel scope link src 133.24.25.175 metric 100 133.24.24.0/23 via 133.24.24.254 dev enp44s0 proto static metric 100 169.254.0.0/16 dev enp44s0 scope link metric 1000
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53 options edns0 trust-ad search .
network managers
Installed:
NetworkManager
Running:
root 727 1 0 14:26 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: enp44s0 GENERAL.TYPE: ethernet GENERAL.NM-TYPE: NMDeviceEthernet GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/2 GENERAL.VENDOR: Realtek Semiconductor Co., Ltd. GENERAL.PRODUCT: RTL8125 2.5GbE Controller GENERAL.DRIVER: r8125 GENERAL.DRIVER-VERSION: 9.008.00-NAPI GENERAL.FIRMWARE-VERSION: -- GENERAL.HWADDR: <MAC 'enp44s0' [IF1]> GENERAL.MTU: 1500 GENERAL.STATE: 100 (connected) GENERAL.REASON: 0 (No reason given) GENERAL.IP4-CONNECTIVITY: 4 (full) GENERAL.IP6-CONNECTIVITY: 3 (limited) GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.0/0000:2c:00.0/net/enp44s0 GENERAL.PATH: pci-0000:2c:00.0 GENERAL.IP-IFACE: enp44s0 GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: Wired connection 1 GENERAL.CON-UUID: 74ab3dfa-6d40-3a80-ac15-e5d79d5a2286 GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/1 GENERAL.METERED: no (guessed) CAPABILITIES.CARRIER-DETECT: yes CAPABILITIES.SPEED: 1000 Mb/s CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: yes INTERFACE-FLAGS.LOWER-UP: yes INTERFACE-FLAGS.CARRIER: yes INTERFACE-FLAGS.PROMISC: no WIRED-PROPERTIES.CARRIER: on IP4.ADDRESS[1]: 133.24.25.175/23 IP4.GATEWAY: 133.24.24.254 IP4.ROUTE[1]: dst = 133.24.24.0/23, nh = 0.0.0.0, mt = 100 IP4.ROUTE[2]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000 IP4.ROUTE[3]: dst = 0.0.0.0/0, nh = 133.24.24.254, mt = 100 IP4.ROUTE[4]: dst = 133.24.24.0/23, nh = 133.24.24.254, mt = 100 IP4.DNS[1]: 133.24.61.2 IP4.DNS[2]: 133.24.61.1 IP6.ADDRESS[1]: fe80::27d7:c858:c237:83df/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 100 CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/1 CONNECTIONS.AVAILABLE-CONNECTIONS[1]: 74ab3dfa-6d40-3a80-ac15-e5d79d5a2286 | Wired connection 1
NetworkManager.state
[main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]] [connection] wifi.powersave = 2
[[/etc/NetworkManager/NetworkManager.conf]] [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]] [main] dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]] [keyfile] unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]] [connectivity] uri=http://connectivity-check.ubuntu.com./
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]] [device-31-mac-addr-change] match-device=driver:eagle_sdio,driver:wl wifi.scan-rand-mac-address=no
NetworkManager profiles
Netplan config
[/etc/netplan/01-network-manager-all.yaml] network: version: 2 renderer: NetworkManager
iw reg get
Region: Asia/Tokyo (based on set time zone)
global country 00: DFS-UNSET (2402 - 2472 @ 40), (N/A, 20), (N/A) (2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN (2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN (5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN (5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN (5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN (57240 - 63720 @ 2160), (N/A, 0), (N/A)
iwlist channels
lo no frequency information.
enp44s0 no frequency information.
iwlist scan
lo Interface doesn't support scanning.
enp44s0 Interface doesn't support scanning.
module infos
[iwlwifi] filename: /lib/modules/5.13.0-39-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko license: GPL description: Intel(R) Wireless WiFi driver for Linux depends: cfg80211 retpoline: Y intree: Y name: iwlwifi vermagic: 5.13.0-39-generic SMP mod_unload modversions parm: swcrypto:using crypto in software (default 0 [hardware]) (int) parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint) parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int) parm: fw_restart:restart firmware in case of error (default true) (bool) parm: nvm_file:NVM file name (charp) parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint) parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool) parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool) parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int) parm: power_save:enable WiFi power management (default: disable) (bool) parm: power_level:default power save level (range from 1 - 5, default: 1) (int) parm: disable_11ac:Disable VHT capabilities (default: false) (bool) parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool) parm: disable_11ax:Disable HE capabilities (default: false) (bool)
[cfg80211] filename: /lib/modules/5.13.0-39-generic/kernel/net/wireless/cfg80211.ko description: wireless configuration support license: GPL depends:
retpoline: Y intree: Y name: cfg80211 vermagic: 5.13.0-39-generic SMP mod_unload modversions parm: bss_entries_limit:limit to number of scan BSS entries (per wiphy, default 1000) (int) parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp) parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
module parameters
[iwlwifi] 11n_disable: 0 amsdu_size: 0 bt_coex_active: Y disable_11ac: N disable_11ax: N enable_ini: Y fw_restart: Y led_mode: 0 nvm_file: (null) power_level: 0 power_save: N remove_when_gone: N swcrypto: 0 uapsd_disable: 3
[cfg80211] bss_entries_limit: 1000 cfg80211_disable_40mhz_24ghz: N ieee80211_regdom: 00
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf] blacklist ath_pci
[/etc/modprobe.d/blacklist.conf] blacklist evbug blacklist usbmouse blacklist usbkbd blacklist eepro100 blacklist de4x5 blacklist eth1394 blacklist snd_intel8x0m blacklist snd_aw2 blacklist prism54 blacklist bcm43xx blacklist garmin_gps blacklist asus_acpi blacklist snd_pcsp blacklist pcspkr blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf] alias net-pf-3 off alias net-pf-6 off alias net-pf-9 off alias net-pf-11 off alias net-pf-12 off alias net-pf-19 off alias net-pf-21 off alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/iwlwifi.conf] remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[ 2.119629] Bluetooth: hci0: Minimum firmware build 1 week 10 2014 [ 2.120490] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi [ 2.648896] enp44s0: 0xffffa491011b0000, <MAC 'enp44s0' [IF1]>, IRQ 18 [ 3.540607] Bluetooth: hci0: Waiting for firmware download to complete [ 8.408556] r8125: enp44s0: link up [ 8.408565] IPv6: ADDRCONF(NETDEV_CHANGE): enp44s0: link becomes ready
########## wireless info END ############
Nmath
  • 12,664
Your device, 8086:51f0, is not covered in the version of the driver iwlwifi included in the default 5.13 kernel included in Ubuntu 21.10. You can confirm this with:
modinfo iwlwifi | grep 51f0
It returns blank.
This thread suggests that it is covered in kernel version 5.17 and later. https://www.mail-archive.com/debian-bugs-dist@lists.debian.org/msg1846969.html
You can install 5.17 with:
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.1/amd64/linux-headers-5.17.1-051701-generic_5.17.1-051701.202203280950_amd64.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.1/amd64/linux-headers-5.17.1-051701_5.17.1-051701.202203280950_all.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.1/amd64/linux-image-unsigned-5.17.1-051701-generic_5.17.1-051701.202203280950_amd64.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.1/amd64/linux-modules-5.17.1-051701-generic_5.17.1-051701.202203280950_amd64.deb
sudo dpkg -i linux*.deb
The driver also requires firmware:
cd /usr/lib/firmware
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/iwlwifi-so-a0-gf-a0-68.ucode
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/iwlwifi-so-a0-gf-a0.pnvm
Reboot.
chili555
  • 61,330
I also had this problem with the same device (8086:51f0) but on Ubuntu 20.04, kernel 5.15.0. Had trouble upgrading the kernel and was also a bit skeptical of the solution, as this message suggests that kernel 5.17rc8 has some issues loading the firmware: https://www.mail-archive.com/debian-bugs-dist@lists.debian.org/msg1847049.html
Instead I followed the suggestion in this other post and it worked right away: Ubuntu 22.04, no WIFI on Alienware x17 R2 with Killer 6E - AX1675 Wifi and Bluetooth card - Bluetooth working fine
sudo apt update
sudo apt install backport-iwlwifi-dkms
(reboot then check if module is properly loaded)
sudo dmesg | grep iwl
