I'm trying to install Maya 2019 on Ubuntu 21.10. I think I have configured everything correctly and I'm close to make Maya work correctly,but unfortunately at the end I get a segmentation error and I don't know how to fix it. Can someone give me some hint ? Below you can see all the commands that I have issued :
apt-get install alien dpkg-dev debhelper build-essential zlib1g-dev
add-apt-repository ppa:zeehio/libxp
nano /etc/apt/sources.list.d
deb http://ppa.launchpad.net/zeehio/libxp/ubuntu/ focal main
apt update / apt upgrade
cd /home/john/Downloads/Maya-Linux/Autodesk_Maya_2019_1_Update_Linux_64bit/rpm/
alien -vc adlmapps14-14.0.23-0.x86_64.rpm
alien -vc adlmflexnetclient-14.0.23-0.x86_64.rpm
alien -vc adlmflexnetserver-14.0.23-0.x86_64.rpm
alien -vc Maya2019_64-2019.0-8580.x86_64.rpm
apt install lsb-core
apt-get install ./adlmapps14_14.0.23-1_amd64.deb
apt-get install ./adlmflexnetserver_14.0.23-1_amd64.deb
apt-get install ./adlmflexnetclient_14.0.23-1_amd64.deb
apt-get install ./maya2019-64_2019.0-8581_amd64.deb
alien -vc pcre-utf16-8.42-6.el8.x86_64.rpm
apt install ./pcre-utf16_8.42-7_amd64.deb
cd /home/john/Downloads/Maya-Linux/Autodesk_Maya_2019_1_Update_Linux_64bit/debs/pcre-utf16_8.42-7_amd64/usr/lib64/
cp libpcre16.so.0 /usr/lib
cp libpcre16.so.0 /usr/lib32
cp libpcre16.so.0 /usr/lib64
alien -vc libpng-1.5.13-8.el7.x86_64.rpm
apt install ./libpng_1.5.13-9_amd64.deb
cd /home/john/Downloads/Maya-Linux/Autodesk_Maya_2019_1_Update_Linux_64bit/debs/libpng_1.5.13-9_amd64/usr/lib64/
cp libpng15.so.15 /usr/lib
cp libpng15.so.15 /usr/lib32
cp libpng15.so.15 /usr/lib64
alien -vc compat-openssl10-1.0.2o-3.el8.x86_64.rpm
apt install ./compat-openssl10_1.0.2o-4_amd64.deb
cd /home/john/Downloads/Maya-Linux/Autodesk_Maya_2019_1_Update_Linux_64bit/debs/compat-openssl10_1.0.2o-4_amd64/data/usr/lib64/
cp libcrypto.so.1.0.2o /usr/lib
cp libcrypto.so.1.0.2o /usr/lib32
cp libcrypto.so.1.0.2o /usr/lib64
cp libcrypto.so.10 /usr/lib
cp libcrypto.so.10 /usr/lib32
cp libcrypto.so.10 /usr/lib64
cp libssl.so.1.0.2o /usr/lib
cp libssl.so.1.0.2o /usr/lib32
cp libssl.so.1.0.2o /usr/lib64
cp libssl.so.10 /usr/lib
cp libssl.so.10 /usr/lib32
cp libssl.so.10 /usr/lib64
/usr/autodesk/maya2019/bin# sudo systemctl status adsklicensing ● adsklicensing.service - Autodesk Licensing Service Loaded: loaded (/lib/systemd/system/adsklicensing.service; enabled; vendor preset: enabled) Active: active (running) since Sat 2022-03-26 23:07:45 CET; 18h ago Main PID: 881 (AdskLicensingSe) Tasks: 8 (limit: 4615) Memory: 5.0M CPU: 22.389s CGroup: /system.slice/adsklicensing.service └─881 /usr/bin/AdskLicensingService --run
ln -s /usr/lib/x86_64-linux-gnu/libtbb.so /usr/lib/x86_64-linux-gnu/libtbb_preview.so.2
ln -s /usr/lib/x86_64-linux-gnu/libtiff.so /usr/lib/libtiff.so.3
ln -s /usr/lib/x86_64-linux-gnu/libssl.so.1.1 /usr/lib/x86_64-linux-gnu/libssl.so.10
ln -s /usr/lib/x86_64-linux-gnu/libpcre16.so.3 /usr/lib/x86_64-linux-gnu/libpcre16.so.0
ln -s /usr/lib64/libpng15.so.15 /usr/lib/x86_64-linux-gnu/libpng15.so.15
ln -s /usr/lib64/libpng12.so.0 /usr/lib/x86_64-linux-gnu/libpng12.so.0
export TMPDIR=/home/john/tmp
/usr/autodesk/maya2019/bin# maya
Stack trace: pthread_kill raise abort /lib/x86_64-linux-gnu/libffi.so.8(+0x2488) [0x7f93712f8488] /usr/autodesk/maya2019/lib/python2.7/lib-dynload/_ctypes.so(+0xfe4f) [0x7f9338952e4f] /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x8ebfb) [0x7f9388596bfb] /usr/autodesk/maya2019/lib/python2.7/lib-dynload/_ctypes.so(+0xec47) [0x7f9338951c47] /usr/autodesk/maya2019/lib/python2.7/lib-dynload/_ctypes.so(+0xecc9) [0x7f9338951cc9] /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0xae395) [0x7f93885b6395] PyEval_EvalFrameEx PyEval_EvalFrameEx PyEval_EvalCodeEx PyEval_EvalCode PyImport_ExecCodeModuleEx /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x14b30e) [0x7f938865330e] PyObject_Call /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x49d61) [0x7f9388551d61] PyObject_CallMethod /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x112dc1) [0x7f938861adc1] /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x113034) [0x7f938861b034] PyImport_ImportModuleLevel /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0xf30af) [0x7f93885fb0af] PyObject_Call PyEval_CallObjectWithKeywords PyEval_EvalFrameEx PyEval_EvalCodeEx PyEval_EvalCode PyImport_ExecCodeModuleEx /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x14b30e) [0x7f938865330e] PyObject_Call /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x49d61) [0x7f9388551d61] PyObject_CallMethod /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x112dc1) [0x7f938861adc1] /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0x113075) [0x7f938861b075] PyImport_ImportModuleLevel /usr/autodesk/maya2019/lib/libpython2.7.so.1.0(+0xf30af) [0x7f93885fb0af] PyObject_Call PyEval_CallObjectWithKeywords PyEval_EvalFrameEx PyEval_EvalCodeEx
sudo /usr/local/bin/maya: line 188: 142424 Segmentation Error /usr/autodesk/maya2019/bin/maya.bin
Fatal error. Attempting to save in /home/john/tmp/john.20220327.2324.ma
The permissions of the tmp folder are :
owner = root(root)
access : read and write
group : root
other access : read and write
Marietto
  • 635
  • 13
  • 40
Unfortunately I've been unsuccessful in getting anything lower than Maya 2020 to run in Ubuntu. Even CentOS8 (which it's SUPPOSED to run on) doesn't work properly. I can license and run the command, but it just hangs and doesn't ever progress. Maya 2020, however, is possible to run at least on Ubuntu 20.04LTS. I'm attempting to install on PopOS 21.1 but I remember in the beginning I tried installing Maya 2020 on Ubuntu 21.10 and it constantly crashed. I've read about downgrading some libraries to make it work but I've at least got a path to 20.04 running both Maya and Motionbuilder 2020 and above. If you ever get 2019 to work, please share as it's very elusive to figure out what's going wrong!
