I'm having an issue were I need to install ansible and PIP but when I go to install the packages, Ubuntu automatically will try and update python to version 3.8. I need to keep version 3.6, and I need all supporting packages to be python 3.6
Take the example below. I want to install pip, but Ubuntu wants to serve me python 3.8. Is there a way to set the version of python I want?
 python3 --version
Python 3.6.15
sudo apt-get install pip:
Reading package lists... Done
Building dependency tree
Note, selecting 'python3-pip' instead of 'pip'
The following packages were automatically installed and are no longer required:
  distro-info-data ieee-data libyaml-0-2
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libexpat1-dev libpython3-dev libpython3.8-dev python-pip-whl python3 python3-dev python3-distutils python3-lib2to3 python3-pkg-resources python3-setuptools python3-wheel python3.8 python3.8-dev zlib1g-dev
Suggested packages:
  python3-doc python3-tk python3-venv python-setuptools-doc python3.8-venv python3.8-doc
The following NEW packages will be installed:
  libexpat1-dev libpython3-dev libpython3.8-dev python-pip-whl python3 python3-dev python3-distutils python3-lib2to3 python3-pip python3-pkg-resources python3-setuptools python3-wheel python3.8 python3.8-dev
  zlib1g-dev
0 upgraded, 15 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/7912 kB of archives.
After this operation, 30.4 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
Nmath
  • 12,664
kyle brown
