I have a lot of pictures from an historical archive. I need to crop them and to flatten them or to apply some perspective. Also, I'm looking for a software that allows me to work this with a great volume of images and then export them to PDF, something like the Cam Scanner app does automatically. Such apps works greath, but I'm looking for a similar software that works on my PC.
ImageMagick from the default Ubuntu repositories can batch resize images quite easily. It can also correct the proportions between the width and height of a batch of images to produce a batch of images that all have identical proportions. All this can be done in ImageMagick with simple one line commands.
The biggest problem that you face is cropping the images to content to remove white space surrounding the images. Sometimes crop to content works and sometimes crop to content leaves white space remaining on one or more sides of the image. Worse than that is that crop to content produces an image that looks deceptively cropped at 100% zoom, but when you zoom in on the image you can see that one or more sides of the image haven't been cropped accurately and the image still has white borders that can make the edges of an image look raggedy. There's no better way to get an accurately cropped image than to zoom in on the image in GIMP and move the cut lines of the crop tool right at the edges of the image.
There is also a potential problem with batch importing images to PDF. Depending on how the images were made two or more identically sized images may appear to be different sizes in a PDF document unless you scale some of the images to fit. For this reason I like to use GIMP to convert .png images to single page PDFs and then concatenate all the pages into one merged PDF document with PDF Chain from the default Ubuntu repositories. If the merged PDF document looks OK then I accept it, otherwise I can scale the PDF pages which are all still open in GIMP so that they all look exactly the same size in the concatenated PDF document. It's possible to measure the relative scale of two images in a PDF document down to a resolution of one pixel using the Screen Ruler app from the default Ubuntu repositories.
All of these programs work great in Ubuntu. The only potential problem is that GIMP's performance is slower on computers that have low-end GPU specs. Conversely GIMP's performance is faster on computers that have high-end GPU specs.
- 122,292
- 133
- 301
- 332
