boot-repair-4ppa200                                              [20220324_2347]
============================== Boot Info Summary ===============================
 => Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for (,msdos6)/boot/grub. It also embeds following components:
    modules
    fshelp ext2 part_msdos biosdisk
 => Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
    File system:
    Boot sector type:  Unknown
    Boot sector info:
sda2: __________________________________________________________________________
    File system:
    Boot sector info:
sda3: __________________________________________________________________________
    File system:
    Boot sector info:
sda4: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector info:
sda5: __________________________________________________________________________
    File system:
    Boot sector info:
sda6: __________________________________________________________________________
    File system:
    Boot sector info:
sdb1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  SYSLINUX 6.04
    Boot sector info:  Syslinux looks at sector 44096 of /dev/sdb1 for its
                       second stage. The integrity check of Syslinux failed.
                       No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /boot/grub/grub.cfg /syslinux.cfg /ldlinux.sys
================================ 0 OS detected =================================
================================ Host/Hardware =================================
CPU architecture: 64-bit
Video: 2nd Generation Core Processor Family Integrated Graphics Controller from Intel Corporation
Live-session OS is Ubuntu 64-bit (Ubuntu 20.04.4 LTS, focal, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: A04(0.4) from Dell Inc.
This live-session is in Legacy/BIOS/CSM mode (not in EFI mode).
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
Partitions info (1/3): _________________________________________________________
Partitions info (2/3): _________________________________________________________
Partitions info (3/3): _________________________________________________________
fdisk -l (filtered): ___________________________________________________________
Disk sda: 298.9 GiB, 320072933376 bytes, 625142448 sectors
Disk identifier: 0xd065a941
      Boot     Start       End   Sectors   Size Id Type
sda1  *         2048    206847    204800   100M ee GPT
sda2          206848 243161576 242954729 115.9G  7 HPFS/NTFS/exFAT
sda3       420341760 625139711 204797952  97.7G  7 HPFS/NTFS/exFAT
sda4       243163134 420341759 177178626  84.5G  5 Extended
sda5       243163136 244211711   1048576   512M  b W95 FAT32
sda6       244213760 420341759 176128000    84G 83 Linux
Partition table entries are not in disk order.
Disk sdb: 28.84 GiB, 30943995904 bytes, 60437492 sectors
Disk identifier: 0x00057670
sdb1  *     2048 60437491 60435444 28.8G  7 HPFS/NTFS/exFAT
parted -lm (filtered): _________________________________________________________
sda:320GB:scsi:512:4096:unknown:ATA ST320LT020-9YG14:;
sdb:30.9GB:scsi:512:512:msdos:Kingston DataTraveler 3.0:;
1:1049kB:30.9GB:30.9GB:ntfs::boot;
blkid (filtered): ______________________________________________________________
NAME   FSTYPE   UUID                                 PARTUUID                             LABEL                    PARTLABEL
sda
sdb
└─sdb1 ntfs     5030364A30363776                     00057670-01                          Ubuntu 20_04_4 LTS amd64
Mount points (filtered): _______________________________________________________
                        Avail Use% Mounted on
/dev/sdb1               25.6G  11% /cdrom
Mount options (filtered): ______________________________________________________
/dev/sdb1              fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
====================== sdb1/boot/grub/grub.cfg (filtered) ======================
Ubuntu
Ubuntu (safe graphics)
OEM install (for manufacturers)
Boot from next volume
UEFI Firmware Settings
========================= sdb1/syslinux.cfg (filtered) =========================
DEFAULT loadconfig
LABEL loadconfig
  CONFIG /isolinux/isolinux.cfg
  APPEND /isolinux/
==================== sdb1: Location of files loaded by Grub ====================
           GiB - GB             File                                 Fragment(s)
            ?? = ??             boot/grub/grub.cfg                             1
================== sdb1: Location of files loaded by Syslinux ==================
            ?? = ??             syslinux.cfg
            ?? = ??             ldlinux.sys                                    1
======================== Unknown MBRs/Boot Sectors/etc =========================
Unknown BootLoader on sda1
Unknown BootLoader on sda2
Unknown BootLoader on sda3
Unknown BootLoader on sda4
Unknown BootLoader on sda5
Unknown BootLoader on sda6
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would not act on the boot.
Martin Thornton
  • 5,996
  • 32
  • 43
