I'm trying to change the default shell for my user. But I keep getting this error:
$ chsh
You may not change the shell for 'flimm'.
$ chsh -s "$(which bash)"
I'm trying to understand why I may not change the shell for my user.
Flimm
  • 44,031
Since you confirmed that /usr/bin/chsh is setuid root (and therefore should allow non-privileged users to change their own login shell), the most likely explanation for this behavior is that either
  • your current login shell was not in the /etc/shells file
or
  • your current login shell was restricted (most likely /bin/rbash)
Ex.
$ grep fish /etc/shells || echo "invalid shell"
invalid shell
$ sudo chsh -s /usr/bin/fish testuser
$ su - testuser
Password:
Welcome to fish, the friendly interactive shell
testuser@t400s ~> chsh -s /bin/bash
You may not change the shell for 'testuser'.
testuser@t400s ~> exit
Note that there is no restriction on root setting a user's login shell to an invalid shell (as here), and doing so does not make an invalid shell valid by adding it to the /etc/shells file.
$ sudo chsh -s /bin/rbash testuser
$ su - testuser
Password:
testuser@t400s:~$
testuser@t400s:~$ chsh
testuser@t400s:~$ exit
If the target shell was absent from the /etc/shells file, you would have received a different message:
$ sudo chsh -s /bin/bash testuser
$ su - testuser
Password:
testuser@t400s:~$ chsh -s /usr/bin/fish
Password:
chsh: /usr/bin/fish is an invalid shell
steeldriver
  • 142,475
You can try with command sudo usermod -s /bin/bash flimm
This can happen if the user is not listed in /etc/passwd, which can happen when the user is authenticated through LDAP or similar.
Xiangkun
  • 181
The user's login shell is kept in /etc/passwd, and is protected from modification by regular users. You can see it with getent passwd $USER.
If your new shell is listed in /etc/shells, you can change it with:
sudo chsh -s $(type -p bash) $USER
As with all manipulations of login info, be sure to have a login session on another terminal (Ctrl-Alt-F3) in case you break something and can't login.
waltinator
  • 37,856
