When booting my Laptop today I noticed my bluetooth and wifi was not working. Both state in the settings that no adapter is found. I started searching for solutions but nothing worked so far, and I've got the impression that at least the wireless network controller should be found. When I do lspci |grep Network nothing gets displayed.
When only using lspci I can at least find my ethernet, USB, ... controllers, but nothing stating wireless, WLAN, or similar. I can neither install additional drivers over Software & Updates as none get displayed, even when mounting a fresh iso and trying to take the drivers from there.
Using sudo lshw -class network gets me:
*-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0.2
   bus info: pci@0000:04:00.2
   logical name: enp4s0f2
   version: 0a
   serial: 00:90:f5:e7:5b:07
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.13.0-37-generic firmware=rtl8411-1_0.0.3 06/18/12 latency=0 link=no multicast=yes port=twisted pair
   resources: irq:19 ioport:d000(size=256) memory:f2104000-f2104fff memory:f2100000-f2103fff
  *-network
       physical id: 1
       bus info: usb@3:2
       logical name: usb0
       serial: 62:82:59:0e:0b:56
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=rndis_host
driverversion=5.13.0-37-generic duplex=half firmware=RNDIS device ip=192.168.194.172 link=yes multicast=yes port=twisted pair
I also tried Ubuntu 20.04 from a Live USB, but no wifi or bluetooth adapters were found there either. Ubuntu is the only system installed.
My guess now is that the hardware somehow broke, it is an older laptop. Is there any way to fix this, is it something different? I would really appreciate any help.
Thanks
EDIT:
lsusb returns:
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 413c:301d Dell Computer Corp. Dell Universal Receiver
Bus 003 Device 004: ID 2717:ff80 Xiaomi Inc. Mi/Redmi series (RNDIS)
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Wyil
