I've come across a number of apps that need to be launched by executing a .desktop file. I understand that Canonical have disabled running these kinds of apps for security reasons. How does one accept the risk and allow these apps to run?
Using the terminal and typing [./MyApp.desktop] works and successfully launches the app but that's not an ideal solution for apps that are run often and it leaves an unnecessary terminal window open. How does one launch a .desktop app by simply double clicking on it in Ubuntu?
Suggestions I've come across that do not work:
  1. Checking the "Allow executing file as a program" box in properties.
  2. Setting the "Open with..." app to "Run Software".
This worked for me running Ubuntu 22.04.3:
  1. Put someApp.desktop file in /usr/share/applications folder
    sudo cp /path/to/someApp.desktop /usr/share/applications
  2. Change file permission
    sudo chmod +wr /usr/share/application/someApp.desktop
  3. Then you can search the app in "Show applications" panel, as if it was installed from the app store.
muru
  • 207,228
I did not know that starting your app by launching the .desktop file is possible, nor does it work on my side.
Here's what I learned when having the same issue:
  • Your file needs to be placed in the directory /usr/share/applications if it needs to be available for all users
  • Your file needs to be placed in the directory ${HOME}/Desktop if it should be available only to the current user
  • The contents of the file must be exactly correct (I used to have [Desktop entry] as the section header but it needed to be [Desktop Entry] with a capital E)
  • You also need to check "Allow executing file as a program" (as you wrote...)
  • I am not sure if you really have to specify a value for "Open with..." (Maybe it is not needed, though I specified "Run Software" as well.)
  • After saving the .desktop file, an icon should appear on the desktop.
  • Right-click that icon. In the context menu which is shown, click "Allow Launching".
  • The icon should change to the application's icon (if one is specified in the .desktop file) and the application should launch after double-clicking the shortcut icon.
Here's an example .desktop file:
[Desktop Entry]
Name=MyApp
Comment=MyApp is my favourite app for everything
Exec=/usr/local/myApp/myApp.sh
Icon=/usr/local/myApp/myApp-icon.png
Type=Application
There's also a way to check the .desktop file for validity:
$ desktop-file-validate myApp.desktop
If there's no output and the return value of the check is 0 (check with echo $?, the shortcut should be fine. If there's an output, it should indicate what's wrong with the file. The return value should be different from 0 (e.g. 1, also use echo $? to check)
TomS
  • 161
Ubuntu 22.04
The ideas presented as answers also apply to Ubuntu 22.04. Here is a test:
copy a desktop file from ~/.local/share/applications to ~/Desktop, then
double-click the .desktop file and Ubuntu 22.04 replies
Invalid Permissions on Desktop File
Also displayed is
Enable option, Allow Executing File as a Program
the option located under
Permissions from Properties (right click menu).
Following that advice works. The right-click menu also has toggle Allow Launching which suffices to run the .desktop file. The Allow Launching toggle also sets Permissions in Properties.
The simplest answer to the question is then: right-click on the .desktop file and select Allow Launching. The icon for the .desktop file changes and double-click launches the .desktop file. To toggle launching, right-click and select Don't Allow Launching.
