I have installed roundcube and roundcube-psql on Ubuntu 20.04 from the packages. At the top of /etc/apache2/conf-available/roundcube.conf there is a single alias which I have uncommented.
# Uncomment them to use it or adapt them to your configuration
Alias /roundcube /var/lib/roundcube
After reloading Apache, the login screen works in a browser when I load http://ipaddress/roundcube, but the /usr/share/roundcube/installer/config.php file cannot be found by http://ipaddress/roundcube/installer/config.php.
https://help.ubuntu.com/community/Roundcube says there should be two alias lines to uncomment, but in the latest source code of Roundcube there's only one alias.
How do I fix this so that I can run the config.php script?
Update:
Roundcube is installed into /usr/share/roundcube, but there are symlinks in /var/lib/roundcube as below:
lrwxrwxrwx 1 www-data www-data 14 Feb 24 2020 config -> /etc/roundcube
lrwxrwxrwx 1 www-data www-data 30 Feb 24 2020 index.php -> /usr/share/roundcube/index.php
lrwxrwxrwx 1 www-data www-data 19 Feb 24 2020 logs -> ../../log/roundcube
drwxr-xr-x 2 www-data www-data 4096 Mar 21 17:16 plugins
lrwxrwxrwx 1 www-data www-data 28 Feb 24 2020 program -> /usr/share/roundcube/program
drwxr-xr-x 2 www-data www-data 4096 Mar 21 17:16 skins
drwxr-x--- 2 www-data www-data 4096 Feb 24 2020 temp
There's index.php linking to /usr/share/roundcube/index.php, but not to the setup scripts. So I added the following symlink:
installer -> /usr/share/roundcube/installer
This allows the installer to run, but on the "create config" step, nothing is generated, so clearly there are more missing links ;-)
This seems like a bug in the package to me. Why create symlinks in /var/lib/roundcube in the first place?
