This was given to decrypt a file but it is not working: openssl des3 -d -salt -in file.des3 -out file.txt -k supersecretpassword123
Using -iter or -pbkdf2 would be better.
bad decrypt
140239690076800:error:0606506D:digital envelope routines:EVP_DecryptFinal_ex:wrong final block length:../crypto/evp/evp_enc.c:599:
I have tried the answer given at How should I change encryption according to *** WARNING : deprecated key derivation used but this doesn't work.
If you are working on the thing I think you are, the solution I found was to try and do this step using their web shell. I believe it is a openssl version issue, but I don't exactly know which problem. I had also messed around with trying this but it didn't fix it. The web shell appears to be on openssl 1.1.1f and does work.
