I downloaded using WindowStore. I searched for Ubuntu 20.04.4 LTS and used that to get and install.
I have just downloaded Ubuntu 20.04.4 LTS but its failing with error messages when I run sudo apt update My windows is
OS Name:                   Microsoft Windows 10 Enterprise
OS Version:                10.0.19044 N/A Build 19044
I am running WSL 2
  NAME                   STATE           VERSION
* docker-desktop-data    Running         2
  Ubuntu20.04LTS         Running         2
  docker-desktop         Running         2
Installation successful!
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.10.60.1-microsoft-standard-WSL2 x86_64)
  • Documentation: https://help.ubuntu.com
  • Management: https://landscape.canonical.com
  • Support: https://ubuntu.com/advantage System information as of Sat Mar 19 19:26:11 GMT 2022 System load: 0.25 Processes: 8 Usage of /: 0.5% of 250.98GB Users logged in: 0 Memory usage: 9% IPv4 address for eth0: 172.29.53.52 Swap usage: 0%
1 update can be applied immediately. To see these additional updates run: apt list --upgradable
The list of available updates is more than a week old. To check for new updates run: sudo apt update This message is shown once a day. To disable it please create the /home/tonycav/.hushlogin file.
tonycav@LAP-8M8NK13:~$ sudo apt update [sudo] password for tonycav:
Err:1 http://archive.ubuntu.com/ubuntu focal InRelease Temporary failure resolving 'archive.ubuntu.com'
Err:2 http://security.ubuntu.com/ubuntu focal-security InRelease Temporary failure resolving 'security.ubuntu.com'
Err:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease Temporary failure resolving 'archive.ubuntu.com'
Err:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease Temporary failure resolving 'archive.ubuntu.com'
Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Temporary failure resolving 'archive.ubuntu.com' W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Temporary failure resolving 'archive.ubuntu.com' W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Temporary failure resolving 'archive.ubuntu.com' W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease Temporary failure resolving 'security.ubuntu.com' W: Some index files failed to download. They have been ignored, or old ones used instead.
tonycav@LAP-8M8NK13:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: bond0: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 36:09:ba:44:25:83 brd ff:ff:ff:ff:ff:ff
3: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 6a:5e:23:15:f5:90 brd ff:ff:ff:ff:ff:ff
4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
    link/ipip 0.0.0.0 brd 0.0.0.0
5: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
6: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:15:5d:91:6f:4e brd ff:ff:ff:ff:ff:ff
    inet 172.29.53.52/20 brd 172.29.63.255 scope global eth0
    inet6 fe80::215:5dff:fe91:6f4e/64 scope link
Permissions
tonycav@LAP-8M8NK13:~$ ls -l /etc/resolv.conf
lrwxrwxrwx 1 root root 29 Mar 19 19:25 /etc/resolv.conf -> ../run/resolvconf/resolv.conf
Host file I commented out all the IPv6
# This file was automatically generated by WSL. To stop automatic generation of this file, add the following entry to /etc/wsl.conf:
# [network]
# generateHosts = false
127.0.0.1       localhost
127.0.1.1       LAP-8M8NK13.localdomain LAP-8M8NK13
<feff>
192.168.0.11 host.docker.internal 192.168.0.11 gateway.docker.internal 127.0.0.1 kubernetes.docker.internal
The following lines are desirable for IPv6 capable hosts
#::1 ip6-localhost ip6-loopback #fe00::0 ip6-localnet #ff00::0 ip6-mcastprefix #ff02::1 ip6-allnodes #ff02::2 ip6-allrouters
