I use Privoxy and recently switched back to Opera as browser. Anything is fine, but one thing is annoying: Everytime I start the computer I have to restart privoxy (sudo /etc/init.d/privoxy restart) or Opera shows an error, that it cannot reach the proxy. What is wrong here?
Asked
Active
Viewed 1,796 times
Lekensteyn
- 178,446
Mnementh
- 307
It's definitely not an issue with Opera. It's a problem with Privoxy. My Privoxy logfile in /var/log/privoxy/logfile mumbles about "Fatal error: can't bind to 192.168.2.3:8118: Cannot assign requested address".
It's caused by this bug: privoxy not start at boot - karmic.
A workaround is available, which delays the startup of Privoxy. Quoted from https://bugs.launchpad.net/ubuntu/+source/privoxy/+bug/427625/comments/17:
Further workaround suggestions: rename /etc/rc2.d/S?0privoxy to /etc/rc2.d/S99privoxy. If even that doesn't work, then edit /etc/init.d/privoxy and replace the do_start function with the following:
((begins)) do_start() { # Return # 0 if daemon has been started # 1 if daemon was already running # 2 if daemon could not be started start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \ || return 1 start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \ $DAEMON_ARGS \ && return 0 # Add code here, if necessary, that waits for the process to be ready # to handle requests from services started subsequently which depend # on this one. As a last resort, sleep for some time. sleep 1 start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \ $DAEMON_ARGS \ || return 2 } ((ends))
Lekensteyn
- 178,446
