Pop up states:
Cannot obtain lock E: Could not get lock/var/lib/dpkg/lock-frontend.
It is held by process 2197 (unattended-upgr)
W: Be aware that removing the lock file is not a solution and may break your system.
E: Unable to aquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?"
What should I do? I do not know if another process is using it!
Nmath
  • 12,664
That error is telling you that unattended-upgrades is currently working on updates.
You need to wait for it to finish.
When it's done you can continue with your manual updates.
Nmath
  • 12,664
I did wait; then updated every fetched update except the ones' that had the prefix "lib"; then I updated the "lib"; everyone did successfully install.
