I have access to only ONE flash drive at the moment and I need to install Ubuntu on said flash drive. I've seen people on YouTube using two different USB flash drives to burn the ISO on one, and then use it to install the OS on the other flash drive. But as I said, I only have this one USB flash drive.
So, the Question is: Is there a way to use Rufus to burn my Ubuntu ISO on this USB flash drive, and then use it to fully install Ubuntu on the same USB flash drive? If not, what can I do? Thanks.
You can use a virtual machine to boot from a virtual CD. Then, install to the correct USB stick in the VM.
sotirov
  • 4,379
jp_
  • 123
