I'm trying to install gcc, but I keep getting this message:
~$ sudo apt install gcc make gdb valgrind git
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
gcc : Depends: gcc-9 (>= 9.3.0-3~) but it is not going to be installed
Recommends: libc6-dev but it is not going to be installed or
libc-dev
valgrind : Depends: libc6-dbg but it is not going to be installed
What should I do?
