I have tried installing Unity2d/3d via the terminal in a way to become more comfortable around the usage of the terminal and have across an issue where when I try and update via the terminal it brings up and error for unity2d/3d. I have copied on what is output once I have used sudo apt update:
Hit:1 http://gb.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://gb.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://ppa.launchpad.net/git-core/ppa/ubuntu focal InRelease
Hit:4 http://gb.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
Get:5 https://hub-dist.unity3d.com/artifactory/hub-debian-prod-local stable InRelease [2,739 B]
Err:5 https://hub-dist.unity3d.com/artifactory/hub-debian-prod-local stable InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BE3E6EA534E8243F
Reading package lists... Done
W: GPG error: https://hub-dist.unity3d.com/artifactory/hub-debian-prod-local stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BE3E6EA534E8243F
E: The repository 'https://hub.unity3d.com/linux/repos/deb stable InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I was using seeing the history on my terminal in the hope that I can see if I have inputted an incorrect command, although i do not see anything wrong I have noticed that I did use the same command twice, would this be reason on why I am getting the above error code?
I am using Ubuntu 20.04.4 LTS 64-bit 3.36.8
karel
  • 122,292
  • 133
  • 301
  • 332
TL;DR
wget -qO - https://hub.unity3d.com/linux/keys/public | gpg --dearmor | sudo tee /usr/share/keyrings/Unity_Technologies_ApS.gpg > /dev/null
sudo sh -c 'echo "deb [signed-by=/usr/share/keyrings/Unity_Technologies_ApS.gpg] https://hub.unity3d.com/linux/repos/deb stable main" > /etc/apt/sources.list.d/unityhub.list'
sudo apt update
sudo apt-get install unityhub
Issue
There is a bug in the "Install the Unity Hub on Linux" section of the Unity documentation.
For step 2 where we add the Unity repository to the Apt list, the documentation states the following command:
sudo sh -c 'echo "deb [signedby=/usr/share/keyrings/Unity_Technologies_ApS.gpg] https://hub.unity3d.com/linux/repos/deb stable main" > /etc/apt/sources.list.d/unityhub.list'
However, when you go to update the list of sources using sudo apt update you will get the following error:
Err:14 https://hub-dist.unity3d.com/artifactory/hub-debian-prod-local stable InRelease
Solution
There is an error in the command. Step 2 should actually be the following: (signedby should actually be signed-by)
This will resolve the sudo apt update command and allow installation of the Unity Hub.
The important bit from the Unity forums link above: https://forum.unity.com/threads/keyring-error.1290203/
wget -o- https://hub.unity3d.com/linux/keys/public
file public
gpg --no-default-keyring --keyring ./unity_keyring.gpg --import public
gpg --no-default-keyring --keyring ./unity_keyring.gpg --export > ./unity-archive-keyring.gpg
sudo mv ./unity-archive-keyring.gpg /etc/apt/trusted.gpg.d/
sudo apt update
Different from @gencoreoperative that change signedby to signed-by that solved this issue.
My case is inverse: using signedby instead of signed-by.
My system:
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.3 LTS
Release:        20.04
Codename:       focal
one
  • 141
$ wget -qO - https://hub.unity3d.com/linux/keys/public | gpg --dearmor | sudo tee /usr/share/keyrings/Unity_Technologies_ApS.gpg > /dev/null
