I want to get rid of the minor annoyance I have for over a year.
I have a Dell XPS 9500 notebook with Ubuntu 20.04, and i3wm installed on top of it.
Every time my notebook wakes from suspend, it pastes the contents of the clipboard. How can I prevent it?
The problem is that I don't know how to even start troubleshooting it;
  • is it because something sends a "ctrl+V" keyboard shortcut?
  • maybe some strange udev rule? There are plenty of udev rules on my system. How do I know which one is suspicious (or even non-standard?)
update:
Power management scripts
The contents of /etc/pm/sleep.d/10_grub-common:
# Tell grub that resume was successful
case "$1" in thaw) [ -s /boot/grub/grubenv ] || rm -f /boot/grub/grubenv mkdir -p /boot/grub grub-editenv /boot/grub/grubenv unset recordfail ;; esac
contents of /etc/pm/sleep.d/xboxdrv:
case $1 in
     suspend|suspend_hybrid|hibernate)
    systemctl stop xboxdrv || :
     resume|thaw)
    systemctl start xboxdrv || :
esac
Contents of /etc/pm/sleep.d/10_unattended-upgrades-hibernate
PATH=/sbin:/usr/sbin:/bin:/usr/bin
SHUTDOWN_HELPER=/usr/share/unattended-upgrades/unattended-upgrade-shutdown
if [ -x /usr/bin/python3 ]; then PYTHON=python3 else PYTHON=python fi
if [ ! -x /usr/share/unattended-upgrades/unattended-upgrade-shutdown ]; then exit 0 fi
case "${1}" in hibernate) if [ -e $SHUTDOWN_HELPER ]; then $PYTHON $SHUTDOWN_HELPER --stop-only fi ;; resume|thaw) # nothing ;; esac
Contents of /lib/systemd/system-sleep/hdparm:
case $1 in
  post)
    /usr/lib/pm-utils/power.d/95hdparm-apm resume
esac
(The command sudo /usr/lib/pm-utils/power.d/95hdparm-apm resume does not cause clipboard pasting)
systemd system-sleep:
The contents of /lib/systemd/system-sleep/nvidia:
case "$1" in
    post)
        /usr/bin/nvidia-sleep.sh "resume"
esac
(The command /usr/bin/nvidia-sleep.sh "resume" does not cause clipboard pasting)
The contents of sudo /lib/systemd/system-sleep/unattended-upgrades:
set -e
if [ "$2" = "hibernate" ] || [ "$2" = "hybrid-sleep" ]; then case "$1" in pre) /usr/share/unattended-upgrades/unattended-upgrade-shutdown --stop-only ;; esac fi
(The command sudo /usr/share/unattended-upgrades/unattended-upgrade-shutdown --stop-only does not cause clipboard pasting)
The contents of sudo /lib/systemd/system-sleep/tlp:
case $1 in
    pre)  tlp suspend ;;
    post) tlp resume  ;;
esac
(The command sudo tlp resume does not cause clipboard pasting)
There are other system-sleep directories. Are they eligible as well?:
$ fd system-sleep
snap/core20/1328/usr/lib/systemd/system-sleep
snap/core20/1361/usr/lib/systemd/system-sleep
snap/core18/2284/lib/systemd/system-sleep
snap/core18/2253/lib/systemd/system-sleep
snap/core/12725/lib/systemd/system-sleep
usr/lib/elogind/system-sleep
