24
I just installed Ubuntu 12.04, I am a big fan of Geany, but now i don't have the terminal at the base of the window. I have tried to change the terminal preferences, without success. any ideas?
ahs3
  • 243
This is because Ubuntu12 lacks libvte.so, or at least the version Geany uses to emulate the terminal. Try this command
sudo apt-get install libvte-dev
kiri
  • 28,986
Manokadobo
  • 292
You can only install to enable the terminal tab: libvte9
Geany uses GTK+ 2.0 so you need libvte9
sudo apt-get install libvte9
Arcadie
  • 79
Did You try to enable Menu-> View -> Show Message Window ? This will enable Geany bottom panel, where on left You will have "Terminal" tab ( the last one ).
dydek
  • 139
