I have Windows10 and Ubuntu on a SSD. Today the startup time was higher than normal, but I don't understand enough of Ubuntu to solve this problem.
Output of command: systemd-analyze
Startup finished in 5.054s (kernel) + 4min 17.984s (userspace) = 4min 23.038s
graphical.target reached after 3min 3.859s in userspace
Output of command: systemd-analyze blame
3min 47.148s fstrim.service
2min 17.095s plymouth-quit-wait.service
     36.871s snapd.service
     32.701s networkd-dispatcher.service
     27.646s udisks2.service
     20.448s dev-sda6.device
     18.779s accounts-daemon.service
     18.752s systemd-journal-flush.service
     17.599s NetworkManager-wait-online.service
     15.899s NetworkManager.service
     14.648s ModemManager.service
     14.055s polkit.service
     13.977s avahi-daemon.service
     13.975s bluetooth.service
     13.224s switcheroo-control.service
     13.217s thermald.service
     12.963s systemd-logind.service
     12.961s wpa_supplicant.service
     10.591s dev-loop5.device
     10.589s dev-loop2.device
     10.588s dev-loop7.device
     10.585s dev-loop3.device
     10.583s dev-loop9.device
     10.486s dev-loop11.device
     10.243s dev-loop14.device
     10.211s dev-loop13.device
     10.162s dev-loop10.device
      9.154s dev-loop15.device
      8.773s dev-loop8.device
      8.590s dev-loop0.device
      8.145s dev-loop12.device
      7.367s dev-loop4.device
      7.174s dev-loop6.device
      6.109s user@125.service
      6.076s dev-loop1.device
      5.027s apport.service
      4.302s gpu-manager.service
      4.257s rsyslog.service
      4.203s colord.service
      4.196s systemd-udevd.service
      4.174s secureboot-db.service
      3.630s gdm.service
      2.586s e2scrub_reap.service
      2.561s systemd-sysctl.service
      2.390s systemd-resolved.service
      2.255s systemd-rfkill.service
      2.214s grub-common.service
      1.863s fwupd.service
      1.812s systemd-random-seed.service
      1.762s snap-bare-5.mount
      1.757s upower.service
      1.694s snap-core-12725.mount
      1.564s apparmor.service
      1.507s snap-core18-2128.mount
      1.491s systemd-tmpfiles-setup.service
      1.474s systemd-modules-load.service
      1.445s snapd.seeded.service
      1.351s snap-core18-2284.mount
      1.279s pppd-dns.service
      1.231s systemd-tmpfiles-setup-dev.service
      1.214s grub-initrd-fallback.service
      1.196s snap-core20-1328.mount
      1.176s snapd.apparmor.service
      1.121s snap-core20-1361.mount
       886ms snap-discord-132.mount
Edit:
Output of command: sudo smartctl -a /dev/sda
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   193   192   021    Pre-fail  Always       -       1333
  4 Start_Stop_Count        0x0032   029   029   000    Old_age   Always       -       71408
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   090   090   000    Old_age   Always       -       7338
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1933
191 G-Sense_Error_Rate      0x0032   001   001   000    Old_age   Always       -       99500
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       92
193 Load_Cycle_Count        0x0032   141   141   000    Old_age   Always       -       178416
194 Temperature_Celsius     0x0022   103   093   000    Old_age   Always       -       40
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
Googling it looks like the most important part of the ouput are those with id 5 and 197, which maybe indicate future ssd failure, is it correct? Should i buy new ssd? Is the ssd causing the high startup time?
