I just installed a fresh Ubuntu 20.04 and also openssh-server, but somehow it is possible to establish a ssh connection with password only.
There are two user on this host machine. Both have an authorized_keys file with their public key in ~/.ssh/ directory.
I know the password of the other user but I don't have his private key on my machine. Somehow I can log into his account. Just to be clear, he gave me his password to test this.
I downloaded the "fresh" config from here and compared the differences in the sshd_config file, since this is the host-side configuration file.
As far as I know, I just changed X11Forwarding to yes and uncommented it.
The following is my sshd_config file on the host machine. Is there anything wrong which could be the cause of this problem?
#   $OpenBSD: sshd_config,v 1.103 2018/04/09 20:41:22 tj Exp $
This is the sshd server system-wide configuration file. See
sshd_config(5) for more information.
This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
The strategy used for options in the default sshd_config shipped with
OpenSSH is to specify options with their default value where
possible, but leave them commented. Uncommented options override the
default value.
Include /etc/ssh/sshd_config.d/*.conf
#Port 22 #AddressFamily any #ListenAddress 0.0.0.0 #ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key #HostKey /etc/ssh/ssh_host_ecdsa_key #HostKey /etc/ssh/ssh_host_ed25519_key
Ciphers and keying
#RekeyLimit default none
Logging
#SyslogFacility AUTH #LogLevel INFO
Authentication:
#LoginGraceTime 2m #PermitRootLogin prohibit-password #StrictModes yes #MaxAuthTries 6 #MaxSessions 10
#PubkeyAuthentication yes
Expect .ssh/authorized_keys2 to be disregarded by default in future.
#AuthorizedKeysFile .ssh/authorized_keys .ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none #AuthorizedKeysCommandUser nobody
For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
Change to yes if you don't trust ~/.ssh/known_hosts for
#IgnoreUserKnownHosts no
Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
To disable tunneled clear text passwords, change to no here!
#PasswordAuthentication yes #PermitEmptyPasswords no
Change to yes to enable challenge-response passwords (beware issues with
some PAM modules and threads)
ChallengeResponseAuthentication no
Kerberos options
#KerberosAuthentication no #KerberosOrLocalPasswd yes #KerberosTicketCleanup yes #KerberosGetAFSToken no
GSSAPI options
#GSSAPIAuthentication no #GSSAPICleanupCredentials yes #GSSAPIStrictAcceptorCheck yes #GSSAPIKeyExchange no
Set this to 'yes' to enable PAM authentication, account processing,
and session processing. If this is enabled, PAM authentication will
be allowed through the ChallengeResponseAuthentication and
PasswordAuthentication. Depending on your PAM configuration,
PAM authentication via ChallengeResponseAuthentication may bypass
the setting of "PermitRootLogin without-password".
If you just want the PAM account and session checks to run without
PAM authentication, then enable this but set PasswordAuthentication
and ChallengeResponseAuthentication to 'no'.
UsePAM yes
#AllowAgentForwarding yes #AllowTcpForwarding yes #GatewayPorts no X11Forwarding yes #X11DisplayOffset 10 #X11UseLocalhost yes #PermitTTY yes PrintMotd no #PrintLastLog yes #TCPKeepAlive yes #PermitUserEnvironment no #Compression delayed #ClientAliveInterval 0 #ClientAliveCountMax 3 #UseDNS no #PidFile /var/run/sshd.pid #MaxStartups 10:30:100 #PermitTunnel no #ChrootDirectory none #VersionAddendum none
no default banner path
#Banner none
Allow client to pass locale environment variables
AcceptEnv LANG LC_*
override default of no subsystems
Subsystem sftp /usr/lib/openssh/sftp-server
Example of overriding settings on a per-user basis
#Match User anoncvs
X11Forwarding no
AllowTcpForwarding no
PermitTTY no
ForceCommand cvs server
OcK
  • 125
Commented-out entries in original /etc/ssh/sshd_config file indicate default values. So
means that, by default, users may authenticate using their passwords. The presence of public keys on its own does not override that.
You'll need to change to
PasswordAuthentication no
to prevent that.
steeldriver
  • 142,475
