When I was trying to install Git on Ubuntu 21.10, I get an error. The command I used to install git is:
sudo apt update
sudo apt upgrade
sudo add-apt-repository ppa:git-core/ppa
sudo apt update
sudo apt install git
The error I encountered was:
$ sudo apt install git
Reading package lists... Done
Building dependency tree... Done
git : Depends: liberror-perl but it is not installable
