I want to upgrade my laptop ram to 32GB but manufacture manual says only 16GB is supported. Laptop: HP 15-ay503tx Motherboard: HP 81EC (Version: 61.30) Processor: Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
dmidecode output:
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 2.8 present.
Handle 0x0028, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 32 GB
Error Information Handle: No Error
Number Of Devices: 2
Handle 0x0029, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x0028
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: SODIMM
Set: None
Locator: Bottom-slot 1(top)
Bank Locator: BANK 0
Type: DDR
Type Detail: Synchronous
Speed: 2133 MT/s
Manufacturer: 0000
Serial Number: 00000000
Asset Tag: 9876543210
Part Number:
Rank: Unknown
Configured Memory Speed: 2133 MT/s
Minimum Voltage: 1.5 V
Maximum Voltage: 1.5 V
Configured Voltage: 1.2 V
Handle 0x002A, DMI type 17, 40 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Bottom-slot 2(under)
Bank Locator: BANK 2
Type: DDR4
Speed: 2133 MT/s
Manufacturer: Micron
Serial Number:
Part Number: 8ATF1G64HZ-2G3B1
Rank: 1
lshw output:
*-memory
description: System Memory
physical id: 28
slot: System board or motherboard
*-bank:0
description: SODIMM DDR Synchronous 2133 MHz (0.5 ns) [empty]
vendor: 0000
physical id: 0
serial: 00000000
slot: Bottom-slot 1(top)
clock: 2133MHz (0.5ns)
*-bank:1
description: SODIMM DDR4 Synchronous 2133 MHz (0.5 ns)
product: 8ATF1G64HZ-2G3B1
vendor: Micron
physical id: 1
serial:
slot: Bottom-slot 2(under)
width: 64 bits
HP Maintenance And Service Manual Page 14
Crucial Motherboard Compatibility
Can I upgrade ram to 32GB(2x16GB)?
