Just a preface, I know there are numerous questions about this, but I do believe that mine is a different case.
Every now and then, after restarting my computer (often after updating Nvidia drivers), my fan speeds go to the moon after booting into Ubuntu. They are very quiet and reasonable in BIOS, but once Ubuntu loads, they quickly reach max speed. There are quite a few fans in my computer, so this is incredibly loud. After doing some research, I ran sensors, and then sudo sensors-detect. I gave it permission to look at everything, and it wrote a file containing:
# Generated by sensors-detect on Thu Feb 24 09:24:58 2022
# Chip drivers
coretemp
After doing this and running sensors, I got this:
acpitz-acpi-0
Adapter: ACPI interface
temp1:        +27.8°C  (crit = +105.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +40.0°C (high = +82.0°C, crit = +100.0°C)
Core 0: +38.0°C (high = +82.0°C, crit = +100.0°C)
Core 1: +40.0°C (high = +82.0°C, crit = +100.0°C)
Core 2: +40.0°C (high = +82.0°C, crit = +100.0°C)
Core 3: +37.0°C (high = +82.0°C, crit = +100.0°C)
Core 4: +38.0°C (high = +82.0°C, crit = +100.0°C)
Core 5: +37.0°C (high = +82.0°C, crit = +100.0°C)
Core 6: +41.0°C (high = +82.0°C, crit = +100.0°C)
Core 7: +35.0°C (high = +82.0°C, crit = +100.0°C)
As you can see, there is no mention of fan speed. I also ran sudo pwmconfig and got this message:
/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
I am able to set fan speed and behavior in the MSI BIOS, but it seems to ignore these changes on Ubuntu startup. I wanted to know if there is a chance that the board limits OS access to these settings, or if there is some specific manual way to add these fans to sensors. I will update if anyone needs anymore specifics. Thank you.
The board is a Z590-A Pro.
Edit (For rtaft), the results of sudo sensors-detect:
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'...               No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               No
Trying family `ITE'...                                      No
Probing for Super-I/O at 0x4e/0x4f
Trying family `VIA/Winbond/Nuvoton/Fintek'...               Yes
Found unknown chip with ID 0xd592
Aaron
  • 43
The issue here is kernel 5.13.0 does not support your chip which is why sensors detect says Found unknown chip with ID 0xd592. Sometimes you can get lucky and the module will work even though sensors-detect doesn't know what module to use, but in this case I don't think that will work. If you search the internet for 0xd592, you will find others who are in this boat.
Options:
  • The simplest is to wait for Ubuntu 22 next month and upgrade, that will have 5.15.0 which will support the chip under module nct6683.
  • The second option is to install https://github.com/Fred78290/nct6687d following the readme there. That should get you working, but keep in mind that this installs as nct6687 and you may run into issues in kernel 5.15.0 since that would normally use module nct6683.
  • Another option would be to get the patch for the nct6683 changes and build the 5.13.0 kernel yourself with the patch which may require rebuilding and patching the kernel every time it updates. (Note that the link may not be the actual final patch that was used, you'd have to compare kernel source code to be sure)
These options will get sensors to read the chip. Once that is working, you can get fancontrol working using steps found in other threads like this Ask Ubuntu thread. You may need to add an entry to /etc/sensors3.conf, I'm not sure if the nct6687d module requires changes there, but nct6683 has this entry appended to the conf file.
Also see this external thread as my main source of information for the 0xd592 chip ID (keep in mind it is not Ubuntu specific).
rtaft
  • 1,920
