Okay, so I was running Ubuntu 11.10 with a dm-crypt/LUKS encrypted file-system and just tried to update to 12.04 with the Update Manager.
It downloaded all the necessary packages and started installing them and suddenly got this error with libc6 : I'm upgrading to Ubuntu 12.04, and the installation is stuck at preparing libc6
Because of this, I had a reboot in the middle of the upgrade because it clearly seemed to have completely crashed.
After that, I can no longer boot Ubuntu. It asks me for the password to open the encrypted partition, says it's successful and I get the boot screen with the dots looping over and over again. The recovery mode doesn't work at all.
I tried booting on a 12.04 live CD to check if my partition was still there. It is but I can't seem to open it. (I don't know if the partition is corrupted or if it's because the live CD is unable to open it).
Anyway, I'm stuck and I fear I might have to format and reinstall everything (which I do not want to do).
Doesn't anybody have any pointers? Any tips? Any help would be greatly appreciated at this point. Thanks.
Okay, so I eventually found a way to solve my problem with this:
Here's what I did to restore the upgrade process:
Boot from a live CD, start a terminal (Ctrl + Alt + T) and do the following commands:
sudo -i
apt-get install lvm2
Then, go to the file explorer (Nautilus) and mount the hard drive in question, which should give you a path to it as /media/[random set of letters and numbers]/
Then, go back to the terminal and do the following commands:
cp /lib/x86_64-linux-gnu/libc-2.15.so [path to your hard drive which you can determine from Nautilus]/lib/x86_64-linux-gnu/
cd [path to your hard drive which you can determine from Nautilus]/lib/x86_64-linux-gnu
rm libc.so.6
ln -s libc-2.15.so libc.so.6
cd /mnt
mount -t sysfs sys [path to your hard drive which you can determine from Nautilus]/sys
mount -o bind /dev [path to your hard drive which you can determine from Nautilus]/dev
mount -t proc proc [path to your hard drive which you can determine from Nautilus]/proc
chroot [path to your hard drive which you can determine from Nautilus]
ls # make sure ls does not complain about libc!
apt-get -f install
apt-get dist-upgrade
At some point, one of the apt-get might "fail" and ask you to do a "dpkg --configure -a". Do it as it solves the problem.
Then, you should be able to reboot. Run "Additional Drivers", "Computer Janitor" and "Update Manager" and you should be good to go. At least, it worked for me.
I has a similar problem a few days ago (any I have an encrypted drive as well) - the solution is not to reinstall everything, but rather to try to patch the system back. Since I am a beginner in Ubuntu, I didn't note down every step I took - but it was smtg from here - I'm stuck between 11.10 and 12.04 with only a read-only system and Upgrade ended Half-way between ubuntu 11.10 and 12.04, how to full upgrade?
Btw, I had also a CD, but didn't help me at all in this process.
Hope that helps
Bgd
