I'm struggling a bit with running Timeshift from command line. My disk structure look like this:
sda 8:0 0 1.8T 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
├─sda2 8:2 0 1G 0 part /run/timeshift/backup
└─sda3 8:3 0 1.8T 0 part
└─ubuntu--vg-ubuntu--lv 253:0 0 100G 0 lvm /
sdb 8:16 0 232.9G 0 disk
└─sdb1 8:17 0 232.9G 0 part /run/timeshift/backup
So, I would like to create a backup on the sdb1 disk, using:
sudo timeshift --create --comments "Test" --tags D --snapshot-device /dev/sdb1
gives me the following:
Mounted '/dev/sdb1' at '/run/timeshift/backup'
Creating new snapshot...(RSYNC)
Saving to device: /dev/sdb1, mounted at path: /run/timeshift/backup
Linking from snapshot: 2022-02-17_19-34-54
Synching files with rsync...
Created control file: /run/timeshift/backup/timeshift/snapshots/2022-02-17_20-51-55/info.json
RSYNC Snapshot saved successfully (111s)
Tagged snapshot '2022-02-17_20-51-55': ondemand
However, when listing using timeshift --list, I get the following:
Mounted '/dev/sda2' at '/run/timeshift/backup'
Device : /dev/sda2
UUID : acd80a0d-761d-441a-8e8a-b5cca5bf7ee9
Path : /run/timeshift/backup
Mode : RSYNC
Status : Not enough disk space (< 12.9 GB)
Select another device or free up some space
No snapshots found
Any suggestions on what I am doing wrong?
Tom
