When I try to install new software, the dpkg and the libllvm12 interrupts the process with the following errors:
 The following packages have mismatched dependencies:
libllvm12 : Break: libllvm12:i386 (!= 1:12.0.0-3ubuntu1~20.04.3) but 1:12.0.0-3ubuntu1~20.04.4 is installed  libllvm12:i386 : Break: libllvm12 (!= 1:12.0.0-3ubuntu1~20.04.4) but 1:12.0.0-3ubuntu1~20.04.3 is installed
E: Mismatched dependencies. Try 'apt --fix-broken install' without any packages (or specify a solution)
Also sudo apt --fix-broken install doesn't work because dpkg comes with an error:
dpkg-deb: error: subprocess <decompression> returned exit status 2
error dpkg: error processing file /var/cache/apt/archives/libllvm12_1%3a12.0.0-3 ubuntu1~20.04.4_amd64.deb (--unpack):
cannot copy extracted data to './usr/lib/x86_64-linux-gnu/libLLVM-12.so. 1' to '/usr/lib/x86_64-linux-gnu/libLLVM-12.so.1.dpkg-new':
end of file or  unexpected stream
/var/cache/apt/archives/libllvm12_1%3a12.0.0-3ubuntu1~20.04.4_amd64.deb
Also, The Ubuntu store is broken, text only, gear icon, and screenshots cannot be found.
Error404
  • 8,278
  • 35
  • 60
