An HP2560P is outfitted with a Fax Modem per the spec. Efax-GTK requires the correct address / location of the Fax Modem:
hw-probe returned: https://linux-hardware.org/?probe=1f34ac6443
lshw returned: https://pastebin.com/raw/E0QX8t3W
lspci returns:
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:16.3 Serial controller: Intel Corporation 6 Series/C200 Series Chipset Family KT Controller (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b4)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b4)
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b4)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b4)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation QM67 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port Mobile SATA AHCI Controller (rev 04)
23:00.0 System peripheral: JMicron Technology Corp. SD/MMC Host Controller (rev 30)
23:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller (rev 30)
24:00.0 Network controller: Intel Corporation Centrino Advanced-N 6205 [Taylor Peak] (rev 34)
What is the terminal command that identifies a modem / fax modem address?
gatorback
  • 6,523
You should be able to query the information via modem manager with the mmcli command in Terminal. For example:
mmcli -L
Found 1 modems: /org/freedesktop/ModemManager1/Modem/4
Note the 4 on the end of the path. Now you can request more details:
mmcli -m 4
/org/freedesktop/ModemManager1/Modem/4 (device id '7d79202d39af4d0e8533a15c8629d4431644676')
Hardware | manufacturer: 'Lenovo' | model: 'H5321 gw' | revision: 'R3C11' | supported: 'gsm-umts' | current: 'gsm-umts' | equipment id: '358993042510275'
System | device: '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4' | drivers: 'cdc_acm, cdc_wdm, cdc_ncm' | plugin: 'Ericsson MBM' | primary port: 'cdc-wdm2' | ports: 'cdc-wdm2 (at), wwp0s20u4i6 (net), cdc-wdm1 (at), ttyACM1 (at), ttyACM2 (gps), ttyACM0 (at)' ...
The serial devices are located at the bottom: ttyAMC0 and ttyACM1. If you have multiple ttyXXXX locations listed, you may have to test each to determine the correct one.
matigo
  • 24,752
  • 50
  • 79
