We have recently purchased 24 computer of HP Prodesk 400 G7 for our lab, we have installed Ubuntu 20.04 LTS and Ubuntu 21.10 through bootable USB drive. But it is showing that No Wifi Adapter found. We have tried several solutions, but none have worked for me. I have used following terminal commands to see the network devices attached:
$ lshw -c network
WARNING: you should run this program as super-user.
*-network
description: Ethernet interface product: Ethernet Connection (11) I219-LM vendor: Intel Corporation physical id: 1f.6 bus info: pci@0000:00:1f.6 logical name: eno1 version: 00 serial: 6c:02:e0:69:2c:a0 size: 100Mbit/s capacity: 1Gbit/s width: 32 bits clock: 33MHz capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.13.0-28-generic duplex=full firmware=0.4-4 ip=192.168.18.20 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s resources: irq:122 memory:f1000000-f101ffff WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
$ lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:9b43] (rev 05)
00:02.0 VGA compatible controller [0300]: Intel Corporation CometLake-S GT2 [UHD Graphics 630] [8086:9bc5] (rev 05)
00:12.0 Signal processing controller [1180]: Intel Corporation Comet Lake PCH Thermal Controller [8086:06f9]
00:14.0 USB controller [0c03]: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller [8086:06ed]
00:14.2 RAM memory [0500]: Intel Corporation Comet Lake PCH Shared SRAM [8086:06ef]
00:16.0 Communication controller [0780]: Intel Corporation Comet Lake HECI Controller [8086:06e0]
00:16.3 Serial controller [0700]: Intel Corporation Comet Lake Keyboard and Text (KT) Redirection [8086:06e3]
00:17.0 SATA controller [0106]: Intel Corporation Comet Lake SATA AHCI Controller [8086:06d2]
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:0687]
00:1f.3 Audio device [0403]: Intel Corporation Comet Lake PCH cAVS [8086:06c8]
00:1f.4 SMBus [0c05]: Intel Corporation Comet Lake PCH SMBus Controller [8086:06a3]
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH SPI Controller [8086:06a4]
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (11) I219-LM [8086:0d4c]
$ sudo lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 04ca:009c Lite-On Technology Corp. USB Keyboard
Bus 001 Device 003: ID 03f0:134a HP, Inc Optical Mouse
It does not showing the wifi hardware or network controller any where. I have also tried to install the wifi drivers and packages using accepted solution presented here but all in vain. Need prophetic remarks on this issue how can i cater this, Thanks in advance.
Filbadeha
  • 101
