I'm a total Ubuntu noob. Trying to get Ubuntu installed for one of my friends cause I build PCs for fun.
He requested for Ubuntu 20.04 LTS. I'm installing Ubuntu fine but I can't seem to get the Wifi module to work.
I remember back then when I did older versions of Ubuntu, there were similar issues with the AX200 as well.
Currently, running an Intel i9-12900K + Asus B660-A Strix motherboard.
Would appreciate any help with this. Thank you!
Edit #1:
ran lspci -nnk | grep 0280 -A3 and got:
> Network controller [0280]: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:7af0] (rev 11)
    DeviceName: Onboard - Ethernet
    Subsystem: Intel Corporation Device [8086:0074]
    Kernel modules: iwlwifi
ran sudo | dmesg | grep iwl and got:
>[    1.764269] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    1.769945] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-63.ucode failed with error -2
[    1.769958] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-62.ucode failed with error -2
[    1.769966] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-61.ucode failed with error -2
[    1.769975] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-60.ucode failed with error -2
[    1.770038] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-59.ucode failed with error -2
[    1.770046] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-58.ucode failed with error -2
[    1.770108] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-57.ucode failed with error -2
[    1.770172] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-56.ucode failed with error -2
[    1.770181] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-55.ucode failed with error -2
[    1.770189] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-54.ucode failed with error -2
[    1.770197] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-53.ucode failed with error -2
[    1.770207] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-52.ucode failed with error -2
[    1.770215] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-51.ucode failed with error -2
[    1.770223] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-50.ucode failed with error -2
[    1.770232] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-49.ucode failed with error -2
[    1.770241] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-48.ucode failed with error -2
[    1.770249] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-47.ucode failed with error -2
[    1.770257] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-46.ucode failed with error -2
[    1.770267] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-45.ucode failed with error -2
[    1.770275] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-44.ucode failed with error -2
[    1.770284] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-43.ucode failed with error -2
[    1.770292] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-42.ucode failed with error -2
[    1.770300] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-41.ucode failed with error -2
[    1.770308] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-40.ucode failed with error -2
[    1.770317] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-39.ucode failed with error -2
[    1.770318] iwlwifi 0000:00:14.3: no suitable firmware found!
[    1.770320] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-hr-b0-39
[    1.770321] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-hr-b0-63
[    1.770322] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
