I am wanting to run a bash script on startup in Ubuntu 20.04 with the terminal visible. The test.sh file is located at /usr/bin/test.sh. I can get the test.sh file to run at startup but not in a visible terminal window.
Contents of test.sh:
#! /bin/bash
echo "hello";
I can not get it to work, I have tried (individually):
Crontab (with and without the '&' and with/without "sudo")
@reboot bash test.sh &
@reboot /usr/bin/test.sh &
@reboot DISPLAY=:0 xterm -hold -e bash -c "bash test.sh" &
@reboot DISPLAY=:0 xterm -hold -e bash -c "bash /usr/bin/test.sh" &
Startup Applications Command
sudo bash /usr/bin/test.sh
/usr/bin/test.sh
Creating a Service at /etc/systemd/system/testService.service
[Unit]
Description = Test Service
[Service] WorkingDirectory= /usr/bin ExecStart= /usr/bin/test.sh
[Install] WantedBy=multi-user.target
And start, enable and checked status..
systemctl start testService.service
systemctl enable testService.service
systemctl status testService.service
But failed to start.
Any help / pointing in a better direction would be appreciated!
To get a GUI terminal window to appear when you run your script:
Add to "Startup Applications" (under command):
bash test.sh
#! /bin/bash
    DISPLAY=:0.0 xterm -hold -e bash helloWorld.sh
Contents of helloWorld.sh:
#! /bin/bash
echo "hello";
For me, this opened an XTerm terminal window upon login and ran the helloWorld.sh script.
Try the below. Create a new script as below (call it say on_load.sh) who's job is to load your actual script. You can make that script run upon booting by putting an entry in your ~/.config/autostart
I am not sure if Ubuntu has autostart in the settings. I did mine in KDE Plasma and there its automated.
#! /bin/bash
konsole --noclose --workdir ~/usr/bin/ -e 'bash -c "~/usr/bin/test.sh; exec bash"' &
If you can't figure out how to put the above script in ~/.config/autostart, here is how it looks on my file. KDE Plasma created a new file inside my ~/.config/autostart called on_load.sh.desktop
That file looks like this:
[Desktop Entry]
Exec=/home/my_username/Documents/scripts/on_load.sh
Icon=dialog-scripts
Name=on_load.sh
Path=
Type=Application
X-KDE-AutostartScript=true
You need to ensure you have permissions to run both scripts.
Ron Chots
  • 36
