When I try to install qtbase5-dev I have a problem with depencencies. What is the procedure to fix such a errors? Please, help newbie.
krzysiek@aps00090646-mb:~$ sudo apt install qtbase5-dev
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: qtbase5-dev : Depends: libegl-dev but it is not going to be installed Depends: libgl-dev but it is not going to be installed Depends: libglu1-mesa-dev but it is not going to be installed or libglu-dev E: Unable to correct problems, you have held broken packages.
When I try manually install packages below I see:
krzysiek@aps00090646-mb:~$ sudo apt install libegl-dev
The following packages have unmet dependencies: libegl-dev : Depends: libegl1 (= 1.3.1-1) but 1.3.2-1~ubuntu0.20.04.1 is to be installed Depends: libgl-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages.
My apt update:
krzysiek@aps00090646-mb:~$ sudo apt update
Hit:1 http://pl.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 https://download.virtualbox.org/virtualbox/debian focal InRelease
Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:4 https://updates.signal.org/desktop/apt xenial InRelease
Hit:5 https://repo.protonvpn.com/debian stable InRelease
Hit:6 https://packages.microsoft.com/repos/edge stable InRelease
Hit:7 https://packages.microsoft.com/repos/ms-teams stable InRelease
Hit:8 https://esm.ubuntu.com/cis/ubuntu focal InRelease
Hit:9 https://esm.ubuntu.com/infra/ubuntu focal-infra-security InRelease
Hit:10 https://esm.ubuntu.com/infra/ubuntu focal-infra-updates InRelease
All packages are up to date.
And when I try:
krzysiek@aps00090646-mb:~$ sudo apt install libegl1=1.3.1-1
The following packages have unmet dependencies: libegl1 : Depends: libglvnd0 (= 1.3.1-1) but 1.3.2-1~ubuntu0.20.04.1 is to be installed E: Unable to correct problems, you have held broken packages.
Edit:
krzysiek@aps00090646-mb:~$ sudo apt install libglvnd0=1.3.1-1
The following packages have unmet dependencies: libqt5printsupport5 : Depends: libqt5gui5 (>= 5.11.0~rc1) but it is not going to be installed or libqt5gui5-gles (>= 5.11.0~rc1) but it is not going to be installed libqt5widgets5 : Depends: libqt5gui5 (>= 5.12.5) but it is not going to be installed or libqt5gui5-gles (>= 5.12.5) but it is not going to be installed libqt5x11extras5 : Depends: libqt5gui5 (>= 5.12.8+dfsg~) but it is not going to be installed or libqt5gui5-gles (>= 5.12.8+dfsg~) but it is not going to be installed qt5-gtk-platformtheme : Depends: libqt5gui5 (>= 5.10.0) but it is not going to be installed or libqt5gui5-gles (>= 5.10.0) but it is not going to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Resolved: I unchecked from SystemUpdateGUI: Virtualbox, Microsoft Teams and Microsoft Edge repos. Next I made sudo apt update. And next:
The following additional packages will be installed:
  libegl-dev libgl-dev libglu1-mesa-dev libglx-dev libpthread-stubs0-dev libqt5opengl5-dev
  libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5xml5 libvulkan-dev libx11-dev libxau-dev
  libxcb1-dev libxdmcp-dev libxext-dev qtbase5-dev-tools x11proto-core-dev x11proto-dev
  x11proto-xext-dev xorg-sgml-doctools xtrans-dev
Suggested packages:
  libx11-doc libxcb-doc libxext-doc default-libmysqlclient-dev firebird-dev libpq-dev libsqlite3-dev
  unixodbc-dev
The following NEW packages will be installed:
  libxcb1-dev libxdmcp-dev libxext-dev qtbase5-dev qtbase5-dev-tools x11proto-core-dev x11proto-dev
0 upgraded, 23 newly installed, 0 to remove and 0 not upgraded.
Need to get 4485 kB of archives.
After this operation, 35.1 MB of additional disk space will be used.
Do you want to continue? [Y/n]
