So I have been trying to solve this problem from several hours for now:
Problem explanation
I bought a new computer (HP OMEN 15) with Windows 11 already installed. I did a dual boot with ubuntu, which perfectly worked... until I booted again on Windows (from GRUB). Then, GRUB disappears and only windows boot manager remains.
So I reinstalled GRUB according to these instructions: https://doc.ubuntu-fr.org/tutoriel/comment_restaurer_grub . And this worked, but the problem remained: upon launch, windows 11 erases GRUB again.
So then I inactivated windows boot manager following these instructions https://unix.stackexchange.com/questions/241809/grub2-gone-every-time-i-boot-windows-10 and I could clearly observe Windows boot manager was set inactive. So after that I reinstalled grub and ran agan efibootmgr but then windows boo manager was not in the list anymore. Ubuntu was standing where it was. So I thought "ok this time the problem is solved".
I double checked in my computer's BIOS: Windows boot manager had also disappeared and only "OS Boot Manager" was to be seen.
Upon boot, my computer properly open GRUB and I had the possibility to boot on ubuntu (which worked), or on Windows (even if there was no "Windows boot manager" either in the output of efibootmgr or in the Boot options list of my BIOS).
But still, when I chose to boot on Windows, the same problem happened again: GRUB disappeared.
Clarification
Hypothesis
What I think (with my low knowledge) it is related to:
  • As Windows boot manager somehow semms to disappear in GRUB's installation process, windows clears everything and restores it upon startup. If so, is there a way to "tell" windows not to look for its boot manager ?
What I need
I am in dire need of help. I would like to solve this disappearing GRUB problem and have a better understanding of what is going on here.
I am aware I may not have been clear enough, but I hope there is enough info for someone to help me !
Thank you for your reading time !
HP computers are locked on to Windows. The BIOS is such that it wipes off any "Boot" sequence of a non windows OS. Whatever you do, Only if GRUB boots first, it will show an option to have Windows or any other OS's to boot. If you let Windows boot up. it will kill the GRUB.
I have toyed around with 2 options:
  1. Manually select the Boot OS. When the computer starts up, use the key F9 (for HP) to manually select the OS to boot. (Even if default is set as Linux in the BIOS, it will be overwritten as Windows when Windows boots up). I have a different EFI partition for Linux in the same disk.
  2. Use an external Boot application. I have used "Grub2Win". https://sourceforge.net/projects/grub2win/
I select the OS manually.
ramussons
  • 121
Could you not try this work around as a part solution make a copy of your grub.cfg file or menuelst place them in your home directory so you do not have to keep reinstalling grub but just past the file back into /boot/grub to protect file from being deleted maybe give it strong permissions to stop windows from messing with it surely if you make it not writeable windows will not be able to delete it not ideal but food for thought
bit
