I created a chroot using the instructions here, substituting focal for lucid. Now I'd like to start installing packages, starting with Python, but I'm not sure what kind of setup I need to perform before doing so.
Currently when I try to install software-properties-common (via apt-get), I get the following errors:
software-properties-common : Depends: gir1.2-packagekitglib-1.0 (>= 1.1.0-2) but it
is not installable
Depends: packagekit but it is not installable
Googling tells me that dpkg --get-selections | grep hold might turn something up, but it does not.
I thought it might be an issue with /etc/apt/sources.list, so I copied that in from the outer installation and refreshed but it didn't change anything.
Edit:
Running sudo apt update gives the following output:
Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Get:4 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Fetched 336 kB in 1s (440 kB/s)
Reading package lists... Done
Building dependency tree
69 packages can be upgraded. Run 'apt list --upgradable' to see them.
