From OneDrive (Windows) or GoogleDrive (Windows) I am used to much more than I currently have in Ubuntu.
The built-in GNOME Online Accounts is not what I want. I've also tried other clients but all do not copy the whole Workspace locally, rather access every file in the cloud, just through the filesystem.
I want a Full local copy and only synchronization to the cloud.
Is there any tool i do not yet know of?
EDIT: found out about rclone but apparently this also does not provide full local copies.
Many thanks in advance.
There is currently no Google Drive client for Linux.
There are many third-party applications that provide some Google Drive access. These are based upon the public Google API.
Those third party applications cannot provide all Google Drive client features, because the official client uses private methods that are simply not part of the public API.
user535733
  • 68,493
You may check out VGrive. From the description it looks like it does what you want.
raj
  • 11,409
You can use "rclone copy" to copy your Google Drive to a local folder and then write a bash script to sync this folder to your Google Drive using "rclone sync" and create a Cron job to run that bash every one hour.
VGrive and ODrive seem like good options. However they failed for me at the Google login process.
Error 401:disabled_client. Sign in with Google temporarily disabled for this app. This app has not been verified yet ba Google in order to use Google Sign In.
Maybe this post could help: Grive2 is not functioning anymore, do we have alternative to get Google Drive working on Ubuntu MATE 16.04 LTS? It uses Wine/PlayOnLinux to install the Windows Client. I don't understand why there is no officially supported Drive Client for Linux-based systems, but it is what it is.
According to user N0rbert's answer from December 2019, the installation is fairly easy.
  1. Install PlayOnLinux sudo apt install playonlinux
  2. Launch PlayOnLinux.
  3. Click Install or Install a program
  4. Type "google drive" in the Search field and select Google Drive Sync Enterprise
  5. Click Install and confirm.
The program should now be located on the Desktop or in Applications > Internet > Google Drive Sync
Please note that as of today (31.01.2023) on Ubuntu 22.04 LTS the download for the Program did not work. PlayOnLinux got itself the required Wine and Gecko packages, but was unable to download the file itself.
For some reason it tries to download WindowsXP
https://web.archive.org/web/20150602122012/http://download.microsoft.com/download/a/b/c/abc45517-97a0-4cee-a362-1957be2f24e1/WindowsXP-KB975337-x86-ENU.exe
Error! Files do not match.
Local: ee4105f798ff522bc09bc1bcacc4596c
Server: 946d00d87e4094f3a6e425e2d538eadd
Edit: Thanks Arthur for the comment. I'll try to include the main points. Sorry to user N0rbert for downright copying, but your description was well on point.
iguanahay
  • 149
